R50/53 who has a rmw head?
Old Sep 27, 2013 | 05:09 AM
R53minime's Avatar
R53minime
who has a rmw head?
Im looking into song a bvh who has a rmw head do you like it and what all do I need to get it to run right?
Old Sep 27, 2013 | 05:46 PM
ACallahan's Avatar
ACallahan
a cam, 440 - 550cc injectors, CAI, header, aftermarket cat.back, 15-19% supercharger pulley. And to top it all off a custom tune. The difference in performance will pucker your butt.
Old Sep 28, 2013 | 01:45 AM
BlwnAway's Avatar
BlwnAway
Not sure exactly what you mean by "run right" so I'll try & help with the basics.
Any of the BVH's RMW or TPR can be bolted on & driven "as is" and the ECU will adapt "well enough" until you can get it tuned, but you should at the very least work a tune into your immediate future.
As far as "Performing" to the best of it's abilities, that's different.
At the very least you need to look into a header (I ran mine for a while w/ the OEM JCW system & not only did I get nowhere near the performance potential I should have, but in order to tune it even close it had to be tuned extremely lean to compensate for the "plugging" effect of the exhaust, which in turn made it so that once I did add the header it had to be re-tuned Immediately in order to not burn something up)
After a header, everything else is just a PLUS and can be worked around with the tune, if you decide not to do everything.
But yes, to get the Full Potential, all of the above steps AC mentioned, should be taken.
Oh, even though you didn't ask I'll add this, any of them are also Completely DD friendly & should work for many miles, mine has 130k on it & the only reason I'm changing it, is to try something different.
Old Sep 28, 2013 | 07:37 PM
R53minime's Avatar
R53minime
I had detroit tuned quote me on putting me one on and they came back at 8000 dollars...no thank you lol I will dobit myself
Old Sep 28, 2013 | 09:36 PM
ACallahan's Avatar
ACallahan
The head is only around $2500 give or take. I cant see them charging that much labor, I had a labor price from my mechanic awhile back for like $500-600 to swap a head.
Old Sep 28, 2013 | 10:45 PM
piston's Avatar
piston
I have the rmw head, header, dominator cam, 440 cc injectors and tune.
I would not go to anyother source for serious performance parts as its of the best quality and engineering. Im not here to say the other brands are bad, just inferior.
Running only 14psi boost through a 14% redux pulley I was able to achieve 255whp.
For reference, I was able to get all parts, labour, tune etc etc for under 6k.
It is extremly reliable as ive driven 1500miles w/o stoping except for gas and still got about 30 mpg. I would not just put on a head and drive it w/o tune.
Call jan, ask him what he thinks the bare minimum would be for the bvh.
Depends on what you want.
What are your goals for the car?
Old Sep 29, 2013 | 09:18 AM
cristo's Avatar
cristo
Alliance Member
I think the MINI freindly shop around here would charge double that, and the dealer - triple that for labor.
Old Sep 29, 2013 | 10:27 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
But you failed to say that for that price is everything you need to be safe installed. Head, header, injectors, tuned ready to drive.
Old Sep 30, 2013 | 07:04 AM
R53minime's Avatar
R53minime
Piston this is my daily driver but my goals are just to make power reliably im going to go with the bvh with invidia exhaust rmw street cam 440cc injectors then the tvs blower whenever it comes out
Detroit tuned I didnt mean anything by it sorry... for everyone they did have a bunch of things included into the quote just wasnt exspecting 8000 dollars to get a bvh to run right
Old Sep 30, 2013 | 07:49 AM
Saltysalt's Avatar
Saltysalt
ive been wondering the same thing about the BVH, but i have heard that doing head work is just as reliable some times more depending on the pressures put on a smaller valve. but shoddy worksmanship will always show.
look at hennesy, he gives a 3 year warranty on his heads since he has proven that his heads are better than factory, creating reliable power
Old Oct 1, 2013 | 01:46 AM
BlwnAway's Avatar
BlwnAway
Honestly when it comes to BVH's & the other ness. goodies, the biggest issue for most people is "sticker shock", mostly because getting the 1st 30-40 extra hp out of your Mini is reletively simple & inexpensive, but that next level is considerably more expensive, and the levels after that are even worse as far as $/hp.
NYMADMINI
Dec 14, 2016 02:33 PM
Fordgt4
Oct 10, 2015 10:42 AM
WhinyR53
Sep 30, 2015 07:36 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
silence2-38554
Sep 28, 2015 12:19 PM
