R50/53 ? re adding coolant after radiator replacement
Old Aug 13, 2013 | 01:27 PM
  #26
Braminator's Avatar
Braminator
Originally Posted by danjreed
Mini Cooper 1959-2000.. Don't forget companies pull that BS all the time with chemical products.
Dex-Cool? No.. Never. Not compatible at all.
http://www.glysantin.de/162-1-G48.html
Factory coolant used is listed above.
I'm not saying its doom and gloom.
I'm not saying its bad if you do a real flush and fill.
But I just don't understand why people knowingly use the wrong stuff.. When it's easy and cheap to get the right stuff engineered for the vehicle.
G-05 Zerex.. Is not the right stuff.
I do agree and if I had to drain and fill my coolant again I would use the OEM coolant though I see no harm in using the Prestone coolant as I have for many years.
Old Aug 13, 2013 | 01:47 PM
  #27
danjreed's Avatar
danjreed
http://www.aftermarketnews.com/Item/...ntifreeze.aspx
Go read that about Zerex being "approved".
They lied before.
Old Aug 13, 2013 | 06:36 PM
  #28
AlexQS's Avatar
AlexQS
This whole thread was a good read, thanks to all contributors.
I knew that that it was the makers of Zyrex that claimed their stuff was okay for MINI, and not MINI approving Zyrex officially.
Didn't realize their (Zyrex/valvoline's) marketing practices were so questionable though.
Neat to learn about the water in Europe too.
Cheers
Old Aug 13, 2013 | 07:09 PM
  #29
Braminator's Avatar
Braminator
IMO as long as it does not contain nitrates, amines or phosphates it will be fine in your MINI. Everything related to issues with coolant is due to water in Europe and these chemicals. We don't have these issues here. Search the web and you will see this over and over. Most coolant today does not have these chemicals, so use what you are comfortable with. I myself am comfortable with using Prestone.
Not to be flamed but this is the same argument over and over about oils.
Old Aug 13, 2013 | 08:43 PM
  #30
danjreed's Avatar
danjreed
First - again - here are the approval codes -
http://www.glysantin.de/files/basf_g...iew_a4_e_1.pdf
Ok, so after a metric_assload of digging.. I found...
the G05 Spec Sheet.. - http://www.univareurope.com/uploads/...n_G05_TDS1.pdf
G05 does.. Contain Nitrates!
and the G48 Spec Sheet - (factory fill coolant for BMW/Mini)
http://www.univareurope.com/uploads/...n_G48_TDS1.pdf
G48 does NOT contain Nitrates!
Look carefully at the Corrosion Performance tests.
The G48 appears to be less damaging to a *modern* engine. with Aluminum and Steel hardware.
G05 appears to be less damaging to a *older* engine that contains parts made of brass lead, and copper.
Zerex G05.. is well... BASFs old G05 Formula. - Here is their product sheet - http://www.valvoline.com/pdf/zerex_g05.pdf
Perhaps its gaskets, or materials.. but if they were "the same" BMW would do what Mercedes does and say you can use BOTH in the car.. which.. they (BMW/Mini) don't say...
I'll stick with the factory stuff.
Old Aug 13, 2013 | 10:33 PM
  #31
Braminator's Avatar
Braminator
Great information thanks for sharing.
Neither does Prestone 50/50. It does not contain amines or phosphates either.
I do question these as the information in both appear to be 10+ years old (Dec 2002) as seen on the links. So is it still relevant in today's modern engines? Is it still the same as it was all those years ago?
I also believe this info would be for Europe as again they have water issues.
Do you have documents that actually show modern engines having issues using anything other then what the OEM recommends?
Just some info
http://www.underhoodservice.com/Arti...uirements.aspx
https://www.northamericanmotoring.co...i-coolant.html
http://www.bimmerfest.com/forums/sho...d.php?t=523954
Old Aug 14, 2013 | 05:07 AM
  #32
danjreed's Avatar
danjreed
Just some info
The information is still viable. BASF has not changed the coolant formulas *When they do they update the number of it.., like they did with the G40/GG40 (VW/Audi G12.. and G12+ coolants). From what I can tell G12+ and G12++ are close to the "Universal - mixes with anything coolants.."
This article from Larry is wrong.. BMW/Mini does not use G05 - http://www.underhoodservice.com/Arti...uirements.aspx I would take BMW/Mini/BASF over Larry's advice.
The other links sites are interesting - the Bimmerfest one being the most useful.
As for the water issue thing. Sure, its all over the internet, but Euro OEMs don't fill cars with tap/unfiltered ground water. So something else must be the reason?
Documented proof?
http://www.glysantin.com/20-1-Engine...-Know-how.html (has some pics)
http://seagrant.uaf.edu/bookstore/bo...r/coolants.pdf (Yes, I know its boats, but its still the same coolant and explains what happens..)
http://www.denso.com.au/Products/Aut...-Your-Radiator (Denso says dont do it.)
http://bd8ba3c866c8cbc330ab-7b26c6f3...s_Glycerin.pdf (While not BMW.. its is a good explanation of the advances in coolant. G11 is BASF G48, G12 is basically Dex_cool.. G13 is now considered "mixable")
http://www.cumminsfiltration.com/pdf.../CFS-B0807.pdf (thanks cummins)
http://www.aagaskets.com.au/PDF/Cool...YourEngine.pdf (just a web blog)
OH LOOK AT ALL THE COOLANTS FORD SELLS - http://www.fordparts.com/Products/Ch...-Coolants.aspx (clearly not all the same)
http://www.aftermarketsuppliers.org/...ish/05-2R1.pdf -
"Since antifreeze is clear when it is manufactured, and water is clear, dye is used to color the antifreeze for identification and marketing purposes. The color of antifreeze is no longer an accurate indicator as to whether it is an IAT, OAT, HOAT or NOAT formulation. Further, some antifreeze manufacturers market a “universal” antifreeze they say is compatible with all OAT, HOAT and NOAT formulations. These "universal" formulas are not for use with IAT and they will not convert an IAT to an LLC/extended life coolant antifreeze. Mixing IAT with OAT, HOAT or NOAT antifreezes will not damage your vehicle’s cooling system; however the mixture will negate the long life/extended life attributes of these formulations."
I think everyone can pretty much agree to use the OE spec'd coolant for your car. And by that I mean, you don't have to march down to the dealer, but as long as you get a spec-matching coolant its ok. Lots of companies make versions of G48..
Companies like to argue against everything to avoid paying for warranty work - This is just an other possible way to shoot yourself in the foot.
Old Aug 14, 2013 | 05:16 AM
  #33
JAB 67's Avatar
JAB 67
Here's my problem: If Valvoline/Zerex makes the 'better' Mini coolant - G48 - why do they encourage you to buy G05?
Old Aug 14, 2013 | 05:26 AM
  #34
danjreed's Avatar
danjreed
They don't.
My point is somehow it got started online that G05 was "ok" or "good" or "better" or "the same" as G48.
Its not.
It says right on the back of the bottle of Zerex to refer to your owners guide.
Here is an article about waterpump damage. - http://www.ricksfreeautorepairadvice...-wrong-coolant
Old Aug 26, 2013 | 09:29 AM
  #35
GreekDrifter91's Avatar
GreekDrifter91
has anyone just used prestone to top off coolant? i plan on taking out my SC this week and probably wont be able to catch all the water so was just thinking to top it off after i put everything back in.
Old Aug 26, 2013 | 10:15 AM
  #36
JAB 67's Avatar
JAB 67
Where in the owner's manual does it help me decide the G-05 vs G-48 question? I can't find it.
Old Aug 26, 2013 | 10:31 AM
  #37
Braminator's Avatar
Braminator
Greek not only have I used it to top it off my mini but for a short time. But now my MINI has been filled with Prestone only the last 4 years with zero issues.
Old Aug 26, 2013 | 10:33 AM
  #38
GreekDrifter91
no i was just concerned with oem stuff and prestone, sometimes they dont like eachother. but sounds good to me. im pretty sure i have the same coolant when the car was made. i should do a flush just dont want to right now.
Old Aug 26, 2013 | 11:09 AM
  #39
AlexQS's Avatar
AlexQS
While I've found this an interesting debate, I thought the one thing we all agreed on was to not mix them.... Maybe I still don't understand all sides of the argument. ::sigh
While I wouldn't mix them in my car, I wouldn't be surprised if mixing them caused no damage at least in the short term time,... So my opinion, if you plan on flushing the entire system in a month or two, it might not matter much what you put in it today.
Old Aug 26, 2013 | 02:18 PM
  #40
danjreed's Avatar
danjreed
It says to use BMW OE coolant.. Which is G48.
Old Aug 26, 2013 | 05:04 PM
  #41
Braminator's Avatar
Braminator
Old Aug 27, 2013 | 05:05 AM
  #42
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
IMHO, when topping off the coolant reservoir and you don't have the proper coolant, it's best to just use distilled water. Even if you were to go to a 25% coolant to water ratio, you'd have sufficient protection for most climates.
Old Aug 27, 2013 | 07:55 AM
  #43
AlexQS's Avatar
AlexQS
Genius!
Cereall
Sep 5, 2019 06:05 PM
blackie
Jan 18, 2017 09:56 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
PSIChocolate
Aug 13, 2015 12:46 PM
BernieCoop
12
Aug 12, 2015 07:45 AM
