R50/53 Brake sensor
Old May 31, 2013 | 05:58 PM
micromini234's Avatar
micromini234
Brake sensor
I was just wondering if its possible to get away with only replacing one brake sensor without getting weird lights and such?
Old May 31, 2013 | 06:07 PM
Braminator's Avatar
Braminator
As long as the other one is not worn out also then yes.
Old May 31, 2013 | 06:14 PM
micromini234
When I bought the car there were no sensors on the brakes. I mean like can I install only a rear sensor, with no front.. without getting lights?
Old May 31, 2013 | 06:21 PM
chrunck's Avatar
chrunck
No, it checks for both. I guess technically you could just hardwire it so it thinks the sensor is still good if you really don't want a sensor at all. It's just checking continuity on the circuit, so it would be really easy to bypass altogether.
Old Jun 2, 2013 | 06:55 AM
Capt_bj's Avatar
Capt_bj
can you explain what you mean by no sensors .... they were bypassed or removed?
Old Jun 2, 2013 | 07:07 AM
ZippyNH's Avatar
ZippyNH
The op has a gen1 car...sensor is bypassed by just reconnecting the cut wire on the sensor. ...and zip tying it out of the way. If either circuit is open...you get a light. So you can bypass one or both...no issues....usually the seneor wire is left in place...and the wires twisted together....resistance if tge wire is important.
Toolman
Jan 20, 2016 06:50 AM
Aug 25, 2015 09:18 AM
jpgwinn24
Tires, Wheels, & Brakes
Aug 23, 2015 02:53 PM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
