R50/53 Clutch bleeding question
Old May 26, 2013 | 05:21 PM
tbearmini's Avatar
tbearmini
I searched and read a bunch of threads about compressing the clutch slave cylinder when bleeding. However, most of the threads deal with pumping the clutch pedal or replacing the slave itself.
If I am using a pressure bleeder and won't be pressing the clutch, will anything happen or does the cylinder need to be compressed to get any fluid through the slave?
Only reason I want to do this is because just changed out the brakes and it looked like the fluid had been there a long, long time.
Old May 26, 2013 | 05:25 PM
Braminator's Avatar
Braminator
As long as you do not bleed it dry you will be ok and won't need to bleed the slave cylinder.
Old May 26, 2013 | 05:32 PM
AlexQS's Avatar
AlexQS
It's too bad they didn't put the bleed valve on the other end of the cylinder..... You won't be able to get the old fluid (nor potential air) out of the clutch slave cylinder without compressing the piston.
You can bleed the line without bleeding the slave though.
Old May 26, 2013 | 05:34 PM
tbearmini's Avatar
tbearmini
The brakes went fine (I actually think the car had the original rotors on it). Since I have the bleeder out was going to put the wrench to the clutch slave and see if I can push any new fluid through it. So I should be okay as long as I don't push the clutch pedal?
Old May 26, 2013 | 05:35 PM
tbearmini's Avatar
tbearmini
Got it. Guess I'll either just leave it or see if someone ever sells the official clutch tool for it.
How can I bleed the line (and is it worth it in your opinion)?
Old May 26, 2013 | 06:40 PM
AlexQS's Avatar
AlexQS
I just did my brakes, and did not do the clutch.
If the reason you're wanting to do it, is because the fluid has been there a long long time, I don't see the point of flushing the line if you're not going to compress the piston to get all that old fluid out of there too.
How's the operation of your clutch?
I did the brakes because its not only a maintenance item, but one that maintains safety at that. There are performance gains to be had with the brakes as well. I didn't see as many benefits with the clutch, and thought flushing the line only is like doing it halfway. There may be some potential corrosion issues that I'm ignoring, but my clutch works fine.
Old May 26, 2013 | 07:23 PM
tbearmini's Avatar
tbearmini
Clutch seems to work fine although it releases pretty close to the floor. I guess I'll wait until I need to replace the clutch slave before worrying about it.
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
Camaro108
Aug 25, 2015 02:44 PM
Gipper
Aug 8, 2015 05:39 AM
