R50/53 25,000+ miles? How reliable has your MINI been?
Old May 9, 2004 | 05:30 PM
  #26
DUCTTAPE's Avatar
DUCTTAPE
31k
Superb. A few problems that Prestige MINI fixed in top shelf fashion.
I have no complaints
David
Old May 15, 2004 | 05:20 AM
  #27
My1stMINI's Avatar
My1stMINI
Now @ 39k. Next service approximately 1000 miles away.
Problems to be addressed include:
- Variety of rattles (sunroof, shifter in 3rd, door, IP)
- Odd non-rattle noises (automatic AC @ start, "percolating" sound when gas pedal lifted in 2nd)
- Salt film on inside moveable windows after each car wash in Spring / Summer
- Both front turn signals cracked (SE Michigan gravel haulers... :evil: )
- Lots and lots of stone chips in bonnet and windshield (same as above... :evil: )
Has anyone considered extending the service warranty from 36k to 48k? Given the cost of a Mini-OEM oil change and service, does this make sense?
Old May 15, 2004 | 06:44 AM
  #28
MINIclo's Avatar
MINIclo
7th Gear Gal
MyFirst,
When I purchased Wanda, I bought the extended maintenance warranty, figuring that by the time she reaches 48K, she'll most likely need at least a brake job, and the extra $$$ for the extension was less than the brake job would be, so I went for it. She is about to pass 30K on the clock on my current cross-country roadtrip and is running better than ever. Of course, her newish K&N CAI Typhoon Kit hasn't hurt....LOL!
Old May 16, 2004 | 11:36 AM
  #29
MG-BGT's Avatar
MG-BGT
32,500 miles on my Dec 02 build 03 MCS that I have driven since January of 03.
Just completed 1st Inspection at 30,000 miles.
Repairs under warranty:
New speedo instrument cluster to replace defective temp indicator.
Replaced driver side window winder motor & controller (failed to operate).
Replaced coolant tank on my own with aluminum tank.
Repainted interior trim on my own after it started peeling off.
Replaced faulty throwout bearing on transmission/clutch.
Replaced PCV hose.
Replaced steering column (bearings failed), so I'm on my second steering columns and the clacking noises have come back, and it appears that the seconds steering column bearings are also beginning to fail.
Still outstanding work: have ordered another new window motor controller, since the window dip function needs to be reset about 2-3 times per week, sometimes even twice a day.
On my current cross-country drive my passenger side xenon headlight started acting up: at times, it will not light up even when trying 5 times in a row. At other times, it will work ok. Took it to a dealer in AZ on the fly, and they said a new light-control computer is needed (not sure if that is the BC1 computer), and so I will have that ordered and replaced when I get back. It is very annoying now to have to pull over every time I have to turn on the lights, and check to see if the passenger side one is on or not!
Have had mild versions of stumble and yo-yo. At Insp 1 upgraded to ECU software version 36, which took care of the stumble and improved the yo-yo, but there is still some yo-yo, but never to the extent that it really bothered me.
None of these issues have kept me from driving the car, and it's the most fun car I have ever driven. On the other hand, the car has had more than 12 dealer visits now (almost one per month on average), and spent over 30 days at the dealer.
It is the most fun car I have ever driven, but also the car with the worst quality I have ever owned or driven, and that by a huge margin. I love the car, and I really hope MINI can get their quality act together. I am going to sell this one and get an 05, but may wait to January so I can get an LSD.
M.
Old May 16, 2004 | 12:25 PM
  #30
05JCWS's Avatar
05JCWS
Hmmm! Let's see. I just passed 25,000 miles and it has been bought back by BMW. So probably not so good. But I had a lemon. Most of the problem has been major engine problems. The rest of the car has been good, except two windshields and a bad amp on my Harmon Kardon. I personally think I had a lemon, and except for the engine problem, it has held up quite well. So much fun, that I had to go and buy another one.
Old Nov 9, 2005 | 09:18 AM
  #31
alamomini's Avatar
alamomini
36000 miles plus
I am just over 36,000 miles and I have the following dealer visit history. I am the second owner btw..
1. windshield replacement
2. o2 sensor
3. window regulator
4. fuel line sending unit
5. a/c compressor
6. rear shock puncture (road hazard) Not a mechanical fault, but due to crappy california interstates
I thought these types of things only happen after the car is out of warranty
Old Nov 9, 2005 | 09:37 AM
  #32
C4's Avatar
C4
33K+ miles, '02 Cooper CVT.
Purchased new: September 7th 2002
Produced at Oxford: August 7th, 2002
No problems at all. Still on original factory windshield. Has traveled over 15K miles in several roadtrips and has visited 11 states.
Hard working daily driver.
Old Nov 9, 2005 | 09:40 AM
  #33
dave's Avatar
dave
pug poo picker-upper
Wow. Surpised to see I was the one that started this thread.
70,000+ miles now.
Old Nov 9, 2005 | 10:46 AM
  #34
whskysouth's Avatar
whskysouth
112,000 Miles....
Powersteering went out around 18K on the way back from Canada. Dealer replaced.
Oil Changes at about 6000-8000 miles. Do my own.
Brake Flush, Coolant Flush, and Seat Belt Light replace at 96,000.
Steering Rack replaced due to extended warranty coverage.
Car has been great!
Old Nov 9, 2005 | 10:52 AM
  #35
The MINITOR's Avatar
The MINITOR
45,000 miles
Transmission, clutch, power steering fan,tires, brakes, oil, seat folding mechanisms, and my dealer sucks (NW MINI).
Last edited by The MINITOR; Nov 9, 2005 at 10:54 AM. Reason: forgot to say who my sucky dealer was
Old Nov 9, 2005 | 11:07 AM
  #36
Electron_Mike's Avatar
Electron_Mike
Nearly 40k miles
Both window regulators replaced due to squeaking
External driver's side A-Pillar cover replaced (cracked)
New tires (wore mine out!)
Old Nov 9, 2005 | 11:49 AM
  #37
DuncanDad's Avatar
DuncanDad
Just under 25K on an 10/05 build MCS...
Both window motors
Clutch master Cylnder
Dash rattle
Cut, (from factory) visor
Re energize AC unit and rerout AC drain
Dealer has been great, Global Imports-ATL
Old Nov 9, 2005 | 12:38 PM
  #38
Bilbo-Baggins's Avatar
Bilbo-Baggins
With my '02 MCS purchased new in October of '02 I had 36,700 smiles with 100% mechanical relibility.
Granted, there were some warranty issues, but they never interfered with my travels. Everything was always handled during regular scheduled maintenance appointments unless parts had to be ordered.
Old Nov 9, 2005 | 01:41 PM
  #39
rwd's Avatar
rwd
about 29K, 03 MC
-coolant turned brown, they refilled it and it's been fine since
-was overheating when idling, turned out the p/s fan was causing fuse to blow and kill the auxiliary fan. they fixed the p/s fan and it's been fine since
-dash rattle started about a year ago. it happens when it's hot so i turn on the a/c through the defroster and that makes it stop.
the service has been great. it's a fantastic car. i love it so much i bought another one (really!)
Old Nov 9, 2005 | 02:15 PM
  #40
blue_rocket2's Avatar
blue_rocket2
No biggies
I have a 2003 (Nov 2002 build) MC with 58,000 miles. I am now out of warranty. Before the warranty expired the following were completed by the dealer:
Fix driver door that would not open from the outside (re-attached cable)
Fix cigarette lighter that stopped working with phone charger
All scheduled and covered oil changes and maintainence
replaced front brakes
Replaced vacuum assist booster for brakes
Reset front passenger seat
Also completed (but not a dealer)
1 OEM windshield replacement (cracked by huge rock after 3 months)
1 PPG windshield (no problems so far)
Also, I am still driving on my original Goodyear Eagle Runflats
Old Nov 9, 2005 | 02:17 PM
  #41
Yucca Patrol's Avatar
Yucca Patrol
My brakes break from time to time.. . . other than that, my MINI has been basically perfect and has never left me by the side of the road for a drivetrain issue. .. . 48k
Old Nov 9, 2005 | 02:37 PM
  #42
xsmini's Avatar
xsmini
As of today 88,400 miles. Worst problem as of yet has been the coolant bottle leaking. Had it replaced under warenty the first time, but the second time I bought a Forge one.
Should be well over 100k by amvivIII
Nik
Old Nov 9, 2005 | 03:23 PM
  #43
Hwydsgnr's Avatar
Hwydsgnr
Sure hope all of these "idiosyncracies" have been addressed in my one week old '06.
Old Nov 9, 2005 | 03:36 PM
  #44
Dr Obnxs's Avatar
Dr Obnxs
62k+
And still going strong. I'm gonna need a a clutch soon. Not too snappy anymore. Everything that's broken, I broke! (maybe not a gas tank sender, but that's just started up)....
Matt
Old Nov 9, 2005 | 03:42 PM
  #45
MGCMAN's Avatar
MGCMAN
37K on a 9/02 production 03 MCS.
No major problems.
recall for defective suspension bolt.
replacement coolant header tank
replaced/upgraded ps fan / coolant fan circuit
minor trim piece replaced due to factory install error
crack in windshield (I live with it, as it hasn't spread)
Love the car as much now as when it was new.
Uncertain and nervous as to what the '07s will bring.
Old Nov 9, 2005 | 04:16 PM
  #46
boognish's Avatar
boognish
2003 MC CVT, May 16 '03 Build Date, June 6, 2003 purchase date at dealer.
38K miles so far... the following repairs:
Driver's side door lock actuator mechanism failed (RUW = Replaced Under Warranty)
Harmon Kardon amplifier stopped working, RUW
Dash rattles: fixed temporarily with silly rubber pieces placed between windshield and dash by dealer...rubber pieces have since slid out of place, rattles back in full force
Steering wheel leather bubbling and peeling: replaced steering wheel with same type that looks like it will also bubble in peel in time...RUW
Overheat situation this summer, car was towed to dealer...required a new power steering electric motor (the PS Fan was fine...it was the PS Motor that failed only...very odd...) RUW
I think that is it...I lost track...hope this car doesn't become a money pit after warranty is expired! Love it and hope to drive it for at least 100K miles but...we'll see...track record isn't too good for a 2 year old car with only 37K miles.
Rock on,
-boognish
Old Nov 9, 2005 | 10:34 PM
  #47
TMGRobyn's Avatar
TMGRobyn
Oct 03 build, Cooper, 48,000.
3rd day of ownership, front whindshield moulding replacement.
Windshield replacement, next day after dealership breaks windshield.
All three service stops, oil changes, brake pads all around.
Window motors replaced.
Rattles in back hatch and dash fixed and have not returned.
Driver's side iwndow re-aligned.
Brakes are probably needing to be replaced again soon. I drive too fast, and stop too often!
No other problems to report. Still smile everytime i get in mine! And I would never ever want to own an automatic. Those poor souls seem to have all the bad cars!
Old Nov 9, 2005 | 10:55 PM
  #48
lotsie's Avatar
lotsie
64k miles. There have been issues, but in terms of the car being reliable it has never let me down
Old Nov 9, 2005 | 10:57 PM
  #49
4GAZM's Avatar
4GAZM
Originally Posted by DiD
Our MINIs are half way through the warranty period at 25,000 miles, so let's see how it's going for those MINIs with more than 25,000 miles.
TD51044 purchased in June of 2002
Year 1: 29,008 miles with ten visits to the dealer and replaced four MINI windshields.
Year 2: (first 10 months): another 14,700 miles (43,700 total) with no warranty repairs and a PPG windshield (the 5th windshield in my MINI) hasn't cracked or rock chipped in 10 months.
well i have over 116,000 miles and have had nearly no probs at all and absolutley 0 problems since 50,000 so i know after i write this my engine will go
Old Nov 10, 2005 | 09:03 AM
  #50
Aquasar's Avatar
Aquasar
Well my MINIhas 22K ond he runs great it has a Production date of May 3 2004. I brought it in for a leaking sunroof gasket, wind deflector deformed and a scheduled oil change next oil change in 4400 miles. So far it really is tropuble free (knock on wood).
Art
