R50/53 Overcharging alternator?
Old Jan 28, 2013 | 07:33 PM
  #26
Braminator's Avatar
Braminator
Is this one any less reliable then the $300 OEM one from Denso
I don't think so. Where are you located?
Old Jan 28, 2013 | 07:36 PM
  #27
be2slow's Avatar
be2slow
Also, what special tool is needed for the mini cooper S (step 8)
I am in Seattle area
Old Jan 28, 2013 | 07:39 PM
  #28
Braminator's Avatar
Braminator
A belt tensioner tool.
Old Jan 28, 2013 | 07:40 PM
  #29
Braminator's Avatar
Braminator
If you were closer I would of offered to help as I have the tool.
Old Jan 29, 2013 | 05:37 AM
  #30
minsanity's Avatar
minsanity
Try sourcing from salvage yards. R50 Densos have slight difference on the shell & won't fit the R53, but they share the same core. Take note that MINI has Valeo, Bosch & Denso supplying alternators for the 1st gen, cross check yours w/ realOEM. It isn't a difficult swap.
Old Jan 29, 2013 | 08:37 AM
  #31
OldGameFreaK's Avatar
OldGameFreaK
Make sure to check the ground strap BEFORE you pull it all apart.
From Pelican's website:
"An important item to check on your car is the engine ground strap. The engine is electrically isolated from the chassis by rubber motor mounts. If the engine ground strap is missing or disconnected, then you might have a whole bunch of problems, including electrical system malfunctions and difficultly turning over the starter. The ground strap is located just in front of the passenger side engine mount"
Also open the phone book and see if you have any alternator shops in town. It sounds like the regulator is bad. That's a part that can be replaced instead of getting a complete new unit. It's IN the alternator. If you can't find one call a NAPA or even a car audio shop and ask them who the recommend.
I have had several alternators fixed or even custom built for me in the past. I have never had any issues having one done.
Old Jan 29, 2013 | 01:26 PM
  #32
martinb's Avatar
martinb
If it says 13 to 15 volts, the voltage regulator is operating correctly. If it's higher than 15, or lower than 13, get it checked out in a garage
Wrong. 13 volts is not enough to charge a lead acid battery. And 15 is way too much. The proper range is in the low 14's. Most systems shoot for 14.4 volts. But some small variation is allowed.
16+ is way, way, way too much and indicates a faulty voltage regulator. Possibly more. No point in bench testing the unit as it's cheaper to simply replace the entire alternator which includes the voltage regulator and rectifier (VRR).
Hopefully you haven't permanently damaged your battery. If it go that hot, I'd replace it anyway to be safe. Optima Red Top for me.
Old Jan 29, 2013 | 01:32 PM
  #33
martinb's Avatar
martinb
Originally Posted by be2slow
Alright, did the test again. Idling, 16.6, and while rev'd it was 16.65. Would you say it's the alternator, or did I test incorrectly?
Also, while off, the battery is at 14.5...which seems higher then it should as well (prob since high charge from alternator.)
Never check a lead/acid battery immediately after it's been charged, either by the car's system or a separate battery charger. The battery voltage will be artificially high. To get an accurate reading, you MUST let the battery sit with no load on it for a minimum of 2 full hours after the charger has been removed/turned off. 6 hours is better. A brand new, fully charged lead acid battery should be 12.8 volts, give or take a tiny bit. Older batteries are OK down to 12.6. Below that and your battery is heading towards the graveyard. Remember, 12 volts is fully discharged, not 0 volts. Thus, 12.6 volts is only 3/4 charged, 12.4 volts is only 1/2 charge.
Old Jan 29, 2013 | 01:41 PM
  #34
Braminator's Avatar
Braminator
Wrong please read.
http://batteryuniversity.com/learn/a...d_acid_battery
http://m.sooperarticles.com/technolo...ry-548495.html
Old Jan 29, 2013 | 02:00 PM
  #35
Braminator's Avatar
Braminator
The typical charging voltage is between 2.15 volts per cell (12.9 volts for a 6 cell battery) and 2.35 volts per cell (14.1 volts for a 6 cell battery). These voltages are appropriate to apply to a fully charged battery without overcharging or damage. If the battery is not fully charged, you can use much higher voltages without damage because the charging reaction takes precedence over any over-charge chemical reactions until the battery is fully charged. This is why a battery charger can operate at 14.4 to 15 volts during the bulk-charge phase of the charge cycle.
Old Jan 29, 2013 | 03:16 PM
  #36
martinb's Avatar
martinb
There's a threshold voltage level that needs to be considered. That's usually around 13.5 volts. Below that and you're not going to be doing any charging, from a practical standpoint.
Old Jan 30, 2013 | 05:40 PM
  #37
be2slow's Avatar
be2slow
Alright guys,
I have called around some shops, and quotes seem to be roughly $800 bucks or so.
I don't mind doing it myself, but reviewing those directions without actually doing anything look confusing, but I am sure once I get going it will make more sense.
That being said, what do you think the required skill level should be for doing something like this? Am I correct in assuming it isn't that bad once you begin, or are there bound to me many unforeseen issues? I don't wanna get involved and get over my head.
Old Mar 3, 2013 | 05:11 PM
  #38
Braminator's Avatar
Braminator
So how are things going since you changed the alternator? Did everything still work out?
Old Mar 3, 2013 | 06:05 PM
  #39
be2slow's Avatar
be2slow
yeah, did it all last week. It was a pain to take everything off, but much easier than expected to put back.
Fired it up, charging at 14v!
Thanks guys, learnede a bunch and saved $600.
Old Mar 3, 2013 | 06:13 PM
  #40
Braminator's Avatar
Braminator
Awesome. Now you know how to put it in service mode if needed again. Good luck.
vulkandino
Oct 31, 2015 08:29 PM
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
jennster
Sep 28, 2015 06:19 PM
daviday
Sep 25, 2015 01:31 AM
