R50/53 A few thoughts about VMAXX Coilovers
Old Oct 24, 2012 | 09:37 AM
  #26
WRXTURBO's Avatar
WRXTURBO
submitaweasel, your car looks good. so youre running VMAXX coilovers, stock wheels, and 12mm spacers in the front? so with at et48 wheel and after spacers, that would change the overall offset to et36?
how much room would you estimate there is between the spring perch and the tire/wheel when the car is down and off jackstands?
Old Oct 24, 2012 | 10:00 AM
  #27
submitaweasel's Avatar
submitaweasel
If the stock offset is et48, then yes. I havent done any research on the stock wheels so don't take my confirmation as the truth
If I recall, I can fit a finger inbetween the wheel and spring perch, with the spacers, so maybe like 1/4" which would mean you SHOULD have clearance with you et40 wheels, (if my overall offset is indeed et36). I'll doublecheck to see how much clearance I have...but the main problem is I can't really see past the wheel when the car isn't on a jack
If that paragraph above makes no sense, it is due to me not really understanding how offset works. If someone wanted to school me, I'd be a happy boy.
There are a whole lot of ifs and assumptions in this post, so I'd suggest not taking my word as truth just yet. I'll try to gather some more information before I head to work.
Old Oct 24, 2012 | 10:30 AM
  #28
submitaweasel
I just did a little research and yes, my wheels are et48 stock, so my 12mm spacers should reduce offset to et36 (I think????)
Also, thanks to settling, there is no way I can even get my hand back there to feel the amount of space I've got with the car on the ground. I'd be willing to bet you'll be fine, but if not, you'd only need 5mm spacers and then you'd have more clearance than me
Old Oct 24, 2012 | 11:03 AM
  #29
WRXTURBO's Avatar
WRXTURBO
okay cool sounds good
well i have seen people with et20 wheels but most of them do not have VMAXX coilovers... which is why i was wondering since the front VMAXX coilovers are not "normal" looking coilovers like the rear ones.
im still waiting for hub centric rings to install the wheels, but once the tires are mounted i will let you know how everything goes. i really hope they clear.
Old Oct 24, 2012 | 11:24 AM
  #30
submitaweasel
Yep, the fronts are a bit of an odd shape since they use the stock macpherson strut mount but thats not even the area I had trouble. The closest part of the coilover to my wheel is the lockring and bottom perch. The fact that the springs themselves are increasing diameter from bottom to top caused no problems for me
Old Oct 24, 2012 | 12:35 PM
  #31
WRXTURBO's Avatar
WRXTURBO
okay great... if you have no problem then i would assume i will be okay too! thanks for the information
Old Oct 24, 2012 | 05:59 PM
  #32
svre46's Avatar
svre46
Originally Posted by submitaweasel
If the app shrinks these photos....
Fronts are about 1/2 way through the adjustment...any lower and I can't make it over the speedbumps to get to my apt and rears are a little under an inch from slammed...any lower and I'd have some decent rubs nearly all the time.
Thanks for the pics. It gives me a good idea of what I am looking at. Car looks good!
Old Oct 25, 2012 | 08:00 AM
  #33
submitaweasel
No problem, gents.
Thanks for the compliments
Old Aug 21, 2018 | 12:12 PM
  #34
Wolfgang Steez's Avatar
Wolfgang Steez
Help!!
I had purchased Vmaxx coilovers, on multiple forums I read that they will slam your mini. I recently installed them and they are not what i expected.. My mini isnt even close to what people were saying or pictured people have posted. Im not sure if I installed them wrong or not, Please Help!
I have purchased aftermarket camber plats to replace oem tophats. The piece under the camber plate has recently been removed.
The front are all the way lowered. The rears have about 4in left.
Ryan Caballo
Sep 10, 2015 10:10 AM
freckles81
Sep 8, 2015 09:48 AM
RIchard Nguyen
Sep 6, 2015 07:21 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
