R50/53 Fixed the alternator... now cherry tree w/ abs, sensor and brake...
Old Jun 22, 2012 | 09:06 PM
mikeym's Avatar
mikeym
Hey Guys,
Going to delve into this tomorrow, but I figured I'd ask for some advice quick.
Replaced the alternator in my car tonight due to a crack in it and the bearing making noise.
Everything went ok... At one point in the evening I remember that in the wiki it said to watch out for the right side brake sensor... I recall putting tension on the black wire that attaches to the blue cylinder thing (which I believe to be the abs sensor) by accident.
Put the car back together and took for a ride. Now I have a cherry tree of lights regarding brake stuff. (abs, low tire, brake, dsl traction control)
Going to start tomorrow looking at the right wheel sensor again (it take it its that "blue cylinder").
I'm assuming a wire just pulled out of the sensor itself or did putting pressure on it do it in and now I'm looking at a new sensor?
Thoughts...
~mikeym
Old Jun 23, 2012 | 07:12 AM
mikeym's Avatar
mikeym
This morning on the way over to my parents house to do the work I got a check engine light when starting the car...
Once at my parents I found a problem. Passenger side wheel sensor wire was rubbing against crank pulley and stripped it, but didn't cut it all the way through.
Spliced wire, I'm sure it should work... But no avail... I reset ECU and took battery wire on and off.
Still have all lights - check engine, tpms, abs, brake on...
Going to the dealer soon unless theres something else I should do?
Mike
Old Jun 28, 2012 | 06:18 PM
DailyDrivenMini's Avatar
DailyDrivenMini
What happened with this?
Old Jul 3, 2012 | 06:54 PM
mikeym's Avatar
mikeym
See this thread:
https://www.northamericanmotoring.co...-2002-mcs.html
Got rid of some of the problem... still have some too...
Toolman
Jan 20, 2016 06:50 AM
Aug 27, 2015 12:25 PM
madmaxxed
Aug 24, 2015 11:56 PM
honderpilot
Aug 24, 2015 09:25 PM
