R50/53 Water temperature range
Old Jun 21, 2012 | 12:11 PM
Braminator's Avatar
Braminator
Just curoius to what the average water temperature is for your R53?
With an extremely hot day like today 95degrees in PA, what temp does your car stay at?
Old Jun 21, 2012 | 03:16 PM
Braminator's Avatar
Braminator
Old Jun 21, 2012 | 03:53 PM
04liquidS's Avatar
04liquidS
My 04 touches the middle line ever so slightly on the right side(colder side).
Side note, I just replaced my waterpump/SC in March. Not that it mattered, thats where it sat before I had SC problems.
Old Jun 21, 2012 | 03:59 PM
Braminator's Avatar
Braminator
Thx for the info. I am hoping to find the actual degrees that people are running at.
Old Jun 21, 2012 | 10:31 PM
sir5150's Avatar
sir5150
On my scan gauge temp ranges from 185 to 200 depending on outside temp
Old Jun 22, 2012 | 04:46 AM
NightFlyR's Avatar
NightFlyR
between 194 and 199 at 75 MPH with 98 indicated outside temp. A/C was on. in stop and go it gets to about 210 before it starts to lower, same outside temp. I do need a S/C and A waterpump as I have the death rattle. Car is an 04 S with pully and CAI, 110K on the OD
Old Jun 22, 2012 | 05:57 AM
ofioliti's Avatar
ofioliti
Regardless of the T outside, the Scangauge indicates 198-202F.
(It is recommended to put in an actual T reader like the Scangauge, because the T needle on the MINI is just an "idiot gauge" that will sit at ~halfway and only shoot up (quickly!) if the engine is overheating. Not much warning given.)
Old Jun 22, 2012 | 07:18 AM
JeffM's Avatar
JeffM
I get 195 to 200 on the highway. I switched the speedo digital display to read this out earlier this week, and watched it on my commute home. Less variation than I expected. Going up hills or stopped for a while it would get a few degrees over 200.
Old Jun 22, 2012 | 11:41 AM
thulchatt's Avatar
thulchatt
Same temps and very good advise.
My low speed fan is out but that is not a problem because I can always see the actual temp on my SG. Never any temp problems unless I get stuck in traffic and then I just turn on the AC to start the fan.
Very nice to know the actual temp with the SG.
Old Jun 25, 2012 | 06:49 AM
OVREZY's Avatar
OVREZY
Not an R53 but an R50, if the air-conditioner is on, my high speed fan will come on at about 214 and will cycle on and off regularly. If the air is not on, the high speed fan will not come on until it hits 234 -- cools to about 215 and shuts down then repeats when it hits 234 again.
Old Jun 25, 2012 | 07:08 AM
autoxjohn's Avatar
autoxjohn
Depends on a million things. If the a/c is on, temps stay lower since the fan is running, etc. Most of the time it'll peak in the 190's and then drop a bit. It regularly runs in the 185 range, but I've seen it over 200 at a long light without the a/c going, etc...
(source: aftermarket gauge)
Old Jun 25, 2012 | 11:05 AM
Eric_Rowland's Avatar
Eric_Rowland
I thought the AC only triggered the low speed fan.
To the OP, my scangauge reads 193 in cruise mode (though I swear a few years ago steady state was in the mid 180's.) Around town it will easily climb into the 200's (and the 220's before I replaced my dead low speed fan.)
Old Jun 25, 2012 | 11:07 AM
autoxjohn's Avatar
autoxjohn
Yeah, the A/C only turns on the low speed fan.
elverado
Jan 18, 2022 02:51 AM
asmasm
Sep 21, 2015 08:23 AM
Filmy
Sep 7, 2015 08:27 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 3, 2015 10:29 AM
