R50/53 R56 brake upgrade feels no different than stock?
Old Jun 11, 2012 | 04:19 PM
  #26
Clubman S Turbo's Avatar
Clubman S Turbo
Eric, they do, but few have a vacuum pump, they simply steal it from a tap on the intake manifold. When you get to turbos, it gets trickier, GM used hydroboost on the 80s Grand Nationals, a hydraulic system derived from their medium duty diesel trucks; that powered the steering and braking. They used no vacuum at all.
Old Jun 11, 2012 | 04:58 PM
  #27
bahawton's Avatar
bahawton
FYI- The TyrolSport Brake Caliper stiffening kit for R53s doesn't really fit the rear calipers. The bushings are about 3/16" too long so they move in the caliper instead of sliding on the stainless steel bolts.
Old Jun 11, 2012 | 05:23 PM
  #28
andyroo's Avatar
andyroo
From reading a few posts about R53 vs. R56 brake feel on the same R56 S calipers, it seems some feel the R56 has too much of a grabby on-off feel vs. the longer pedal travel and smooth progression of the R53. Some prefer the R56.
I don't like a mushy pedal, but I don't want an on-off switch. The pedal feels pretty good in my R53 with stoptech pads so as long as it doesn't get noticeably worse I'd be happy when I switch to R56 calipers.
I'm still interested in seeing what sort of changes you feel if you swap MCs.
- drew
W0TM8
Dec 19, 2019 07:50 AM
minimofo
Dec 26, 2015 11:45 AM
marendt428
Aug 8, 2015 04:44 AM
