R50/53 Replacing the glove box
Old May 26, 2012 | 02:10 PM
xbritt's Avatar
xbritt
Hello, I've searched but can't find a link to a 'how to' replace my 03 glove box. I bought a used one, now I need to unistall and install. Any threads here?
Old May 26, 2012 | 02:24 PM
mastertrixter's Avatar
mastertrixter
http://www.mini2.com/forum/first-gen...glove-box.html
here ya go
Old May 26, 2012 | 05:43 PM
xbritt's Avatar
xbritt
Thanks. I had found that one, and in the end it did help. Just did it....relatively simple. For other searchers, here's what I did. 1) Look at the center of the back wall of the glovebox. There is a screw there, unscrew it. 2) Look at the top front rim of the box, you'll see a right screw and a left screw, unscrew them. 3) Look at the right side and left side front edges of the box, you'll see a screw on each side, recessed, unscrew them. 4) You'll have to get your hand under and up the outside left of the box to unplug the little AC hose (if you have one) 5) Now you can pull the glovebox straight out. Remember to unplug the glovebox interior light at the top before you pull it all the way out. Ta Da! NOTE - watch for the 2 plastic screw pieces (blue) that the top screws go into. They may fall out. Just go in reverse to install new glovebox. It's not hard.
blackie
Jan 18, 2017 09:56 PM
StuRat
Aug 24, 2015 06:24 PM
blackie
Aug 23, 2015 08:44 PM
minipopkart
Aug 13, 2015 05:22 AM
