R50/53 I need help.! R53
Old May 26, 2012 | 11:03 AM
Stefuhneex33's Avatar
Stefuhneex33
I need help.! R53
Hi my name is steph. An I have a r53 and it's been acting strange I just replaced the throttle body on the car because it would start then die. I connected it to the computer it told me my flap was only opening 17%. So now that I replaced my throttle body the car runs fine except one thing. When the car is idling, it idles very rough. And will shoot up to 2000rpms then shoot back down and it will constantly do this. My brakes are also harder to push at times which I'm assuming is from not being driven in 2months. I also disconnected the MAP sensor which only made a slight difference. Please help me. I'm running out of ideas. I love my mini but it's becoming too much work.
Old May 26, 2012 | 11:12 AM
Hound_va's Avatar
Hound_va
Double check your work as it sounds like you have a vacuum leak.
Old May 26, 2012 | 07:42 PM
Mjimport's Avatar
Mjimport
^ditto, always check and double check vacuum, always the cheapest fix.
Old May 27, 2012 | 05:54 AM
minsanity's Avatar
minsanity
+1 on vac leak. Also check your coils & plugs. Bad gas also gives those same symptoms. Hope you could share 1s you get it figured out.
Old Jun 12, 2012 | 03:38 PM
Stefuhneex33
Thank you everyone for the answers. You acctualy just let the car get use to the new throttle. After a few days it was running fine. Your car needs to adjust
matthewbrakeii
May 13, 2021 08:39 AM
MORENOJM
Sep 20, 2016 08:13 PM
ROCNDAV
Oct 20, 2015 01:08 PM
slipmagt
Aug 22, 2015 02:14 PM
