R50/53 fog lite retro kit
Old May 9, 2012 | 08:21 PM
trashmanbob's Avatar
trashmanbob
fog lite retro kit
Installing front fogs lites, got the oem kit from ECS, How do I find out on the plugs in the fuse box where the pin # are on the plugs. Any body help.
Old May 9, 2012 | 09:51 PM
rkw's Avatar
rkw
The plug should be marked with pin numbers. You need to look very closely. Numbers should be molded in the plastic and very small. Often the pins won't be individually numbered, just the first and last numbers on a row (e.g. in a row of 5 pins, just 1 and 5 may be marked and you can figure out the others).
Old May 9, 2012 | 10:25 PM
ACEkraut11's Avatar
ACEkraut11
The search function here on NAM is not always friendly. Often you can find more by searching Google and adding "North American Motoring" to what ever search terms you are using. There are quite a few threads on the front fog light install. Here is a link to such a thread as well as a link to the Factory MINI Installation Instructions:
Thread:
https://www.northamericanmotoring.co...og-lights.html
Instructions:
https://www.northamericanmotoring.co...t_Retrofit.pdf
Old May 10, 2012 | 04:23 AM
trashmanbob
Fog lite plugs
Thank you for your help. I have a lot more ? for you if it is Ok.
But I have to go to work now will post tonight.
Thanks Bob
Old May 12, 2012 | 08:03 AM
trashmanbob
Sorry, been very busy but have alot questions. Will get back soon
Thanks Bob
Dec 23, 2015 10:36 AM
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
Aug 19, 2015 12:51 PM
