R50/53 CVT Fluid Change
Old Feb 17, 2004 | 06:35 AM
StillK's Avatar
StillK
I recently took my Mini to the dealer for the 1st checkup. They changed the oil and filter, changed the ventilation filter washed the car (and I don't mean to ***** but Stevie Wonder would have done a better wash job). They also attempted (not successfully mind you) to fix a rattle in the back hatch area. In the Mini warranty manual the 1st check clearly includes CVT fluid change. I was unable to pick up the car until after the service department was closed and checking the paperwork after - it appeared that the CVT fluid had not been changed. I called the dealer and discussed the issue with the service writer. He claims the CVT is a sealed unit and fluid change is not necessary. I talked to the sales rep and he claims they did have a problem with incorrect fluid in some early CVTs but that it is not necessary. I called ASK Mini for clarification - they said that it clearly states in the manual that the 1st checkup includes CVT fluid replacement - the rep also checked with others and also reported no indication that the recommendation had changed.
My question to other CVT owners - did the dealer change the fluid on your 1st checkup?
My concern is the possibility of a failure down the road and not having it covered because the manufacturers recommendations were not met.
Old Feb 17, 2004 | 06:59 AM
C4's Avatar
C4
Come over to MINI2.com and join the growing number community of CVT owners! See you there!
http://www.mini2.com/forum/forumdisplay.php?f=624
whosurgaddy
Aug 29, 2015 09:50 AM
Aug 25, 2015 09:33 AM
HaveATank
Aug 24, 2015 10:26 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
