R50/53 Suspension upgrade R53
Old Feb 3, 2011 | 04:52 PM
fastautoxmini's Avatar
fastautoxmini
Want to upgrade the stock suspension on my '05 R53. I have the helix camber plates, so was wondering was suspension works under those camber plates? I was looking to possibly do coilovers or just change the struts. I was thinking of doing koni yellows, but I can't get to the adjuster on the top with the camber plates there. I run 205-55-16 tires and have little clearance in the rear between the tire and the rear suspension. So I can't lower the car all that much. I have 56k on a car that has gone from daily driver to fun weekend car/track car only. So everyday use is not a consideration. Any info/suggestions you can give me will be greatly appreciated.
Old Feb 3, 2011 | 07:48 PM
veggivet's Avatar
veggivet
You may want to consider Koni FSD's, as they won't lower the car very much. Nice shock for street and track.
Old Feb 3, 2011 | 10:47 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
The FSDs aren't supposed to lower the car at all, you can only use them with stock springs.
Old Feb 4, 2011 | 04:25 AM
veggivet's Avatar
veggivet
There are lots of threads on NAM about the amount of lowering that actually occurs with the FSD's, and after having them installed on my R53, I can say that they do lower by about 1/4 to 1/3 inch. As you said, they should be used with stock springs.
Old Feb 4, 2011 | 04:47 PM
fastautoxmini
Thank you for the recommendations. I will check out the other threads as well.
W0TM8
Dec 19, 2019 07:50 AM
Ryan Conaway
Aug 18, 2015 07:45 AM
sabjcw
Aug 14, 2015 07:40 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
