R50/53 Hex head screw stripped!
Old Jun 2, 2010 | 02:19 PM
Barrettrw11's Avatar
Barrettrw11
hey guys. I have a few hex head screws that are stripped and I have no idea how to get them off. They are on the intercooler. Anyone have any ideas as to what I could do?
Old Jun 2, 2010 | 02:36 PM
quikmni's Avatar
quikmni
First, I suspect the hex head screws you are refering to are actually Torx Bit heads. The Torx bit heads will strip if you use an allen head wrench on them. Here are some options:
- If you have been using on allen head wrench you might try the proper size Torx bit to see if it will grab enough to remove the screw.
- Try grabbing with vise grips but there is not much to grab onto so it probably will not work.
- Cut a slot in the screw head and use a screwdriver to remove. Try a small cutting wheel on a dremal tool.
- Try an easy-out. You drill a hole in the head and use the easy out to try and screw the bolt out.
- Drill out (off) the screw heads, to remove the head, by using a drill bit a little larger than the screw threads. When the head is removed, you can remove the IC cover and grab the remaining screw threads with vise grips or small pipe wrench.
Old Jun 3, 2010 | 04:20 AM
Capt_bj's Avatar
Capt_bj
http://www.harborfreight.com/12-piec...set-40349.html
should find similar at any hardware or autoparts store
and yes they are torx
http://www.harborfreight.com/8-piece...set-35187.html
Old Jun 3, 2010 | 04:33 AM
Barrettrw11
Well needless to say I am an idiot for using allen wrenches. I did find the correct torx bit and was able to get everything off and my fuel injectors in. Thanks for the help guys!!
Old Jun 3, 2010 | 06:26 AM
quikmni's Avatar
quikmni
Glad everything worked out OK.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
minimofo
Sep 30, 2015 12:26 AM
COOPT UP
Sep 11, 2015 04:59 AM
Sep 4, 2015 03:56 PM
Sep 3, 2015 10:45 AM
