R50/53 How do I fix sloppy door hinges?
Old Oct 19, 2009 | 02:13 PM
blacter's Avatar
blacter
Opening the driver's door on my recently purchased 2002 Mini is not a happy experience. It just seems a bit too loose and sloppy. All the hinge fasteners seem nice and tight, so I'm stumped for the moment.
Any suggestions? Thanks.
Old Oct 19, 2009 | 02:21 PM
NightFlyR's Avatar
NightFlyR
I had the same issue on my 04MCS, I lossened the Hinge and moved it closer to the body of the car and then tightend it, I also put a few small (quarter inch size ) rubber mounts in the door jams, the door not only is aligned better it closes perfectly now with a much tighter seal
Old Oct 19, 2009 | 03:55 PM
blacter's Avatar
blacter
Thanks, JRoca. Could you give me a little more detail about the 1/4-inch rubber mounts. What exactly did you use and where did you place them?
Old Oct 19, 2009 | 04:03 PM
NightFlyR's Avatar
NightFlyR
You can get them at home depot, the little things you put under a chair or table so you dont scratch the floor is what I used. 3 on each door
1 right by the latch on the actualy door, and 2 on the bottom seem of the door. Sounds much more solid when I close it now
xpunisherx
Nov 27, 2015 03:32 PM
mrjolliff
Oct 9, 2015 05:55 AM
Filmy
Sep 7, 2015 08:27 PM
spackletooms
Sep 1, 2015 10:12 PM
Aug 27, 2015 12:25 PM
