R50/53 Must have mods???
Old Mar 11, 2009 | 07:31 AM
  #26
quikmni's Avatar
quikmni
+1 on Bigshot's suggestion on camber plates instead of re-enforcement plates. Camber plates also replace the top rubber strut bearing (that will rip/tear over time) with a steel bearing. If you go with camber plates make sure to verify that they do not increase the ride height. The Hotchkis (H-Sport) camber plates do not increase ride height.
My first MCS I did the rear sway bar first than adj. camber plates (because towers were mushroomed and to rubber bearing ripped). My second MCS I did adj camber plates first and have not found it necessary to add a larger rear sway bar. I might some day but it is now a low priority.
Old Mar 11, 2009 | 09:16 AM
  #27
KandyRedCoi's Avatar
KandyRedCoi
cool alright, thanx for clearing that up! i will def consider the camber plates
as far as lowering the car i want to have performance and looks, i am actually looking into the Eibach, Tein or HR coilover set ups
and i will actually use K&N filter just because they last forever
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
eMINI of the State
Oct 2, 2015 03:12 PM
B1mm3r101
Oct 1, 2015 06:22 AM
WhinyR53
Sep 30, 2015 07:36 AM
