R50/53 Inner CV boot install
Old Feb 23, 2009 | 02:16 PM
JIMJMN's Avatar
JIMJMN
I have a split inner CV boot and have ordered a new one. Do I have to remove the control arm and steering tie rod to do this? Do I have to drain the transmission? Whats the simlest way to do this install?
Old Feb 23, 2009 | 05:05 PM
jhiggs26's Avatar
jhiggs26
You don't have to drain trans fluid as long as you leave the inner cv joint alone and slide out the half shaft. Make sure to clean the joint up and re-lube before slamming it home! You don't need to remove the control arm either; just pop the outer ball joint.
Jeremy
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
jziran
Aug 24, 2015 04:50 PM
