R50/53 Brake parts interchange?
Old Dec 22, 2008 | 12:08 PM
tgmedin's Avatar
tgmedin
Can anyone tell me if the front brake pad/rotor combination is interchangeable between 03MCS and 05MCS??
I don't have access to a parts listing at the moment.
Thanks guys,
Tom in PA
Old Dec 22, 2008 | 02:04 PM
AutoXCooper.com's Avatar
AutoXCooper.com
Hey Tom, I think they are, but please get the BUILD dates off both MINI's and then hit www.realoem.com and check the numbers. If there are different numbers look at the parts, sometimes MINI changed the part number for a year, but didn't change the part itself.
Old Dec 22, 2008 | 06:55 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Yup Pads and rotors from 02-06 MCS are all the same. The only difference you may come across is the early 02-03 stock pads didn't come with the groves to fit the brake pad sensors. But if by some chance you had that, you could always just tie the sensor back.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Indimanic
Aug 14, 2015 03:14 PM
Mikal68
Aug 13, 2015 07:10 AM
