R50/53 Oil leak from the oil filter.
Old Dec 8, 2008 | 06:35 PM
MrCooperS's Avatar
MrCooperS
Moderator
I changed my oil and filter 2 weeks ago. Today I had a leak from the oil filter. My mechanic (a technician from Herb Chambers Toyota) took a look at it and replaced it with a new filter and o-ring. Told me filter was loose and did not fit snug. I took a look at the new filter's receipt and the old receipt and the it's the same filter. I don't want it to leak again in another 2 weeks. Is this the end of my problems or is there more?
Old Dec 8, 2008 | 07:04 PM
AutoXCooper.com's Avatar
AutoXCooper.com
My partner shop and I have checked out a few of the aftermarket oil filters and have found most of them do not fit just right and the O ring seems to be a weak link. Do you know what brand you have?
We like the http://www.hengst.de/conpresso/_rubr...ter_Systems_EN hard to find, but great fit and product.
Old Dec 8, 2008 | 07:07 PM
MrCooperS's Avatar
MrCooperS
Moderator
STP
Old Dec 9, 2008 | 03:21 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
The "O" ring would be the cause of the leak. I had a loose fitting "O" ring from an OEM filter I bought from MiniMania.COM.
Does the 04 use the same oil filter housing as the 05???
Old Dec 9, 2008 | 04:16 AM
k_h_d's Avatar
k_h_d
Last oil change I tried a Napa gold filter. It leaked as you are describing. I switched back to OEM and the O-ring on the OEM is significantly thicker. Only OEM from the dealer for the filter from now on.
Old Dec 9, 2008 | 04:47 AM
Fatherdeth's Avatar
Fatherdeth
Funny you mention that. Today, I changed fuel filters on 4 generators. When I did the first one, it leaked. So, I took it back off and compared it to the OEM filter that I had taken off. Sure enough, the o ring was a lot thicker than the replacement filter. In some cases OEM is better.
Old Dec 9, 2008 | 06:36 AM
Yo'sDad's Avatar
Yo'sDad
Classic Mini sells the OEMs for $7.86 ea.
I buy them three at a time. Don't forget to pre-fit the filter and use grease on the o-ring and the inside of the housing when you put it all back together.
YD
woodstudio
Mar 15, 2020 08:28 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
gmonde
Sep 8, 2015 06:37 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
