R50/53 Engine Balance Failed?
Has anyone ever heard of this? Recently my 2006 Mini Cooper (2.5 years old, less than 19,000 miles) made a some metal scrapping noise, the engine light and battery light went on and then became hard to steer. So I pulled over and had it towed to the nearest mini dealer. After a few days they returned it with saying the problem was due to "Engine balance failed causing belt to break". They replaced the belt, vibration damper, and hex bolt. Someone told me that this is a serious problem and the car will never be the same
. Does anyone know if this is true?
First of all, I want to know which belt. The only belt on the car drives the front accesories, one of which is NOT the power steering pump as it's electric. There is no timing belt, it's a chain and if that broke, the car is dead in the water. I wonder if the belt broke, caused the alternator to not chage the battery and that's how you lost steering. If the dampner went, that would explain it.
Harmonic balancers have been known to fail on many cars. Because engine shut down as soon as it happen the chances of it doing any engine damage is slight to none.
Agree, harmonic balancers are put on the crank pulleys to deflect torque from cylinder fire. Shutting it down should pretty much ensure no further damage was done.
thebordella
Aug 31, 2015 01:37 PM
Lex2008
Aug 31, 2015 12:12 PM
R50/53 Replacement AC compressor??
PrimePower
Aug 16, 2015 06:29 PM
Drivetrain Won't hold idle after work performed
Lt. Dan
Aug 10, 2015 08:23 AM
