R50/53 DIY Coolant Flush
Old May 19, 2008 | 06:40 PM
  #26
Xymox's Avatar
Xymox
Originally Posted by Hamhocks
I just had mine flushed yesterday. If you have a Valvoline lube shop in your area they will double flush it with G-05 and it is all done with vacuum. Very cool process and the holding tanks are clear so you can see the old and new coolant.
What did that cost you (total)?
Zerex G-05 is great stuff.
Old May 19, 2008 | 07:09 PM
  #27
Hamhocks's Avatar
Hamhocks
I don't know where my reply went? Anyway $79.95, but buy a turkey baster on the way home. Once the coolant expanded the was about 16oz. excess.
Old May 19, 2008 | 07:23 PM
  #28
Xymox's Avatar
Xymox
Got one (even though the woman isn't crazy about me stealing kitchen utensils).
Thanks again.
Old May 19, 2008 | 07:30 PM
  #29
jrprich's Avatar
jrprich
How much was the flush
Old May 19, 2008 | 07:36 PM
  #30
Xymox's Avatar
Xymox
$79.95 (see above).
Old May 19, 2008 | 07:59 PM
  #31
jrprich's Avatar
jrprich
Thanks,
I will check into it here, but I am pretty leary about these places.......there are many horror stories about Quick Lube places.
Old May 19, 2008 | 08:46 PM
  #32
Ancient Mariner's Avatar
Ancient Mariner
AM,
So we have a T in the heater line to push the water in.......easy with the Prestone kit.
But the hose fitting at the upper radiator hose has me confused. Wouldn't we need the drain hose to be at the lower radiator hose rather than the upper ?
BTW,
What do you use to hold the old coolant for disposal/recycle ?
1) Want the water to flow up thru the radiator for reverse flow.
2) Schucks/Checker/Kragen (Shuck's in your area) carries a green recycle container similar to the oil drain containers, for antifreeze. The hard part is finding someplace that will take it. The county waste collection sites around here have tanks for that sort of thing.
Old May 20, 2008 | 06:58 AM
  #33
jrprich's Avatar
jrprich
Actually the disposal issue is what bothers me the most.
My recycle curbside pickup takes my Mobil 1.......but not Antifreeze.
Old May 20, 2008 | 09:26 AM
  #34
jrprich's Avatar
jrprich
AM,
The BMW part number for the upper elbow is 17127515487-BOE Pipe Elbow (or 17 12 7 515 487-BOE with the spacings).
Cost from Pelican is $5.25 (w/another $5.50 shipping ) .
I went ahead and ordered one as I would rather do my work on a new part than disable the MINI during the process.
Once it arrives I will try to drill and tap it for a 1/2" pipe thread.
If that is sucessful I will try to install a 1/2" MPT to 3/4" MHT brass adapter to which we can connect a regular garden hose to serve as the drain/exit point of the flush process.
Will post pics and results IF this works.
Jim
Old May 20, 2008 | 10:44 AM
  #35
jrprich's Avatar
jrprich
Hmmmm,
Called three Valvoline lube shops in my area.........NONE will touch a MINI
They all cite issues with the oil filter canister. I pointed out that I was asking about a Coolant Flush, but they say no MCs.
Old May 20, 2008 | 11:54 AM
  #36
Ancient Mariner
jrprich;
couple of #'s you can call for disposal:
Portland Metro area - 503.234.3000
outside Metro area - 800.732.9253
List of places around Portland area that take AF can be found here:
http://www.deq.state.or.us/lq/pubs/f...Antifreeze.pdf
Looking forward to what you do with the elbow. Not sure about drilling and tapping plastic for a fitting, but possibly a thru fitting with threaded nut/seal on inside might prove to be strong enough. I'm looking at some 1 1/4" sanitary plumbing elbows (the plastic is much heavier than the MINI elbow)
Old May 20, 2008 | 02:54 PM
  #37
jrprich's Avatar
jrprich
jrprich;
Thanks,
Had the numbers but the sites are miles away and at $4 a gallon........well you get it.
As to the plastic elbow. Just a place to start........if you find a more suitable subsitute, please let us know. But I think with some JB Weld around the threads it may be fine unless the OEM elbow is really thin wall.
Old May 24, 2008 | 01:38 PM
  #38
jrprich's Avatar
jrprich
Irony is a biach
So all this talk about doing a coolant flush......my wife calls me on her cell says She is a couple of blocks from home and the MINI is SMOKING
She gets home, coolant is all over the engine and undecarrage......the fans are running like a 747 jet engine. I let if cool down, looks like the radiator cap failed.......it was 1/2 open. Seems to be all out of coolant, so I remove the upper radiator hose and loosen the two bleeder valves and fill her back up with a 50/50 mix...........NO NEED TO FLUSH IT NOW
Old May 24, 2008 | 09:07 PM
  #39
Ancient Mariner
Hot Flush!
Hope the engine's ok'
-skip-
Old May 29, 2008 | 03:13 PM
  #40
jrprich's Avatar
jrprich
Hot Flush!
-skip-
A VERY HOT flush.............
Seems to be OK now.
I am still waiting on the top hose elbow from Pelican..........once I finally get it I will advise on how durable it looks for a hose tap for flushing.
Old May 29, 2008 | 04:54 PM
  #41
Xymox's Avatar
Xymox
Just and FYI, these guys http://www.ecstuning.com carry MINI parts are cheaper then Pelican, and have impeccable customer support.
Old May 29, 2008 | 05:22 PM
  #42
jrprich's Avatar
jrprich
Thanks, They did have the elbow for $4.85
Old May 29, 2008 | 06:54 PM
  #43
Ancient Mariner
I await your findings with bated (baited? ooo) breath.
Old Jun 22, 2008 | 06:23 PM
  #44
Xymox's Avatar
Xymox
How'd you ever make out, jrprich?
I may go the route of calling my local Valvoline station and seeing if they'll touch a MINI. Last coolant flush I did (on a Subaru), I nearly drowned in the green stuff.
Old Jun 22, 2008 | 06:26 PM
  #45
jrprich's Avatar
jrprich
I had my cap fail and pump out almost all the old coolant under heat and pressure ........no damage done, but it was a HOT FLUSH. So after she cooled I just refilled 50/50 with the correct coolant
Old Apr 28, 2012 | 08:34 AM
  #46
Kooperscooper's Avatar
Kooperscooper
Anyone know of a thread that explains heater core replacement and system flush for an R53?
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
M7Speed
Oct 1, 2015 07:05 AM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
