R50/53 What OEM Options Can be Added?
Old Jun 2, 2010 | 08:19 AM
  #26
bond007's Avatar
bond007
Also interested in hearing about the MFSW/cruise control option. I've seen that on Realoem. it lists the retrofit kit, but also lists a "line cable", which is basically the one that conveys the switch info. to the main harness, but is this included with the kit, or does it need to be bought additionally???
Old Jun 6, 2010 | 06:35 AM
  #27
howardholton's Avatar
howardholton
I added: parcel shelf and the newer arm rest/center console to my '03 - not too hard. Instructions were worthless, about 2 hours of cursing. Do not remember cost, I was working at a local dealership at the time.
As to the MFSW - I tried to retrofit, but if the wiring is in place to start with it is very easy, if it is not (and not in the wheel, but available where the wheel harness connects to the car harness, then it is probably not worth it.
According to the MINI techs at the time (2005/06) the MINI's came with several different possible harnesses based on what options were ordered with the car and what harness they had available (there is a lot of inconsistency in the assembly) so - if you have it great, if not - good luck. I am not so lucky, my car does not have the required harness parts to retrofit the MFSW nor cruise control.... too bad for me.
Old Jun 6, 2010 | 08:06 PM
  #28
ACEkraut11's Avatar
ACEkraut11
Do you know what are the telltale signs of a wiring harness that will accept a retrofit MFSW?
Old Sep 27, 2010 | 07:16 AM
  #29
mmcdonald's Avatar
mmcdonald
Has anyone install Automatic Headlights? It seems that my 05' MCS has the sensor on the dash, but doesn't have the auto headlight option on the turn signal lever.
Old Jan 6, 2011 | 02:47 PM
  #30
shredthegnar's Avatar
shredthegnar
Did any one figure out anything with the cruise control?
blackie
Oct 2, 2015 07:41 PM
blackie
Aug 23, 2015 08:44 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Dashdog
Aug 10, 2015 06:17 AM
