R50/53 E-brake Question
Old Sep 6, 2007 | 12:55 PM
skiman747's Avatar
skiman747
E-brake Question
If you drive forward with your ebrake up enough to cause your brake light to come on does this cause your DSC to light up also? I have a 04 MCS and trying to find out if the brake light is causing the DSC light.
Old Sep 6, 2007 | 07:06 PM
mylittlemini's Avatar
mylittlemini
according to MINI one notch up activates the light and applies no pressure to the brakes. at 2 notches pressure is applied and at 4 notches the wheels should lock up. if at one notch one of the rear calipers is slightly appling pressure and the other one is not, then the DSC controller might turn on the light due to different speeds coming from the rear wheels.
you could try jacking up the rear and setting one noth on the e-brake and see if either wheel spins freely. if they both do spin freely then your gonna have to get the codes read to see whats causing the lights.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
OdzBodkinz
Sep 11, 2015 07:20 PM
cinnabun
Sep 11, 2015 05:55 AM
marc0011
Sep 10, 2015 10:04 PM
