R50/53 More Questions...
Old Aug 21, 2007 | 10:09 PM
soccergolf55's Avatar
soccergolf55
More Questions...
Ok, so you guys have been VERY helpful in letting me know some things about my MINI. Now I have just a couple more questions for group of experts...
1. Has anyone had a problem with there glove box staying closed? Mine keeps opening up anytime I go over a bump. (Kind of annoying)
2. When I do my brake job is there a way of getting around using the brake sensor. I change my brakes fairly regularly and I do not require the sensor. So if there is something I can use to fool the system with or do to make the light go out for good I would really like to know.
That is all for now, but I am sure I will come up with more in the not so distant future. Thanks
Old Aug 21, 2007 | 11:14 PM
ScottRiqui's Avatar
ScottRiqui
My glove box stays closed, but there may be some adjustment in the hinges or latch that would help yours.
As for the brakes - if the wear sensor has worn all the way through and activated the dash light for the brakes, I think you have to replace it - it's a consumable item. But if it hasn't worn through yet, you can just ziptie the sensor out of the way and rely on periodic visual inspections to make sure your pads still have plenty of meat on them. This is a fairly common practice, because some of the popular aftermarket pads don't have provisions for the wear sensors.
Old Aug 22, 2007 | 05:38 AM
Roeri's Avatar
Roeri
My '02 did the same thing. I ended up having to replace the box alltogether. It's not very expensive if you have MINI do it, but you can get a better deal aftermarket...
jasonsjwou
Sep 17, 2009 07:19 PM
Tank
Jul 6, 2008 06:30 PM
Aonach
R55 :: Clubman Talk (2008+)
25
Dec 23, 2007 03:28 PM
PirateMini
Jun 18, 2007 10:59 AM
