R50/53 How long did your OE battery last?
Old Jul 5, 2013 | 06:24 PM
  #226
eaglebeagle's Avatar
eaglebeagle
mine is still in there from late 2007 when the car hit the pavement as far i know.( just over 57000 miles) can't find any stamps on it anywhere. Although i do want to replace it soon so i won't have to unexpectely
Old Sep 25, 2013 | 01:06 PM
  #227
faer's Avatar
faer
well my 04/2005 R53 original battery produced 15/05 died on Monday!!! that’s 8 years and 5 months!!!...replaced it with a Bosch S6 65D...Brazilian made (I'm in Chile)
the only thing is that driving around today I suddenly got the EML and traction control lights on, went to limp mode and the engine started working unevenly...so to the mechanic it went!!!
I replaced the harmonic balancer, belt and put in a 17% SC pulley a year ago…so I don’t think is something on that side…
Asked to check and clean sensor, change fuel filter and check for the belt tensioner…..any other ideas?...
Old Nov 30, 2013 | 10:25 PM
  #228
Skeffers's Avatar
Skeffers
8 years to the day of ownership.
Old Dec 1, 2013 | 05:24 AM
  #229
gestero's Avatar
gestero
Three years, but this is typical for any car battery in Fl. the heats kills.
Old Dec 15, 2013 | 07:14 AM
  #230
1711tab's Avatar
1711tab
5 years and 52,000 miles in Phoenix, Arizona...
Old Dec 15, 2013 | 12:18 PM
  #231
joe_706's Avatar
joe_706
8 years and 40000 miles in Spain
Old Dec 15, 2013 | 06:34 PM
  #232
56 Blue's Avatar
56 Blue
Just checked and the date code on my post is 39 06, so it is original battery! About 7 years so far.
Old Dec 15, 2013 | 11:09 PM
  #233
neuralstatic's Avatar
neuralstatic
replacing my 2006 R53 oem this week -- so about 7 years. it's had idle periods and had a couple trickle charges after going dead.
Old Dec 16, 2013 | 09:16 AM
  #234
Tab32's Avatar
Tab32
I'm still using my original battery in mine lol just waiting for it to die
Old Dec 18, 2013 | 07:23 PM
  #235
RoundelWrencher's Avatar
RoundelWrencher
Just replaced the original battery in my '04 S that I picked up about a month and a half ago. The date code on the battery terminal was from '03!
Been lurking on here for a bit but saw thread and had to add since the battery in my new (to me) MINI was over 10 years old! I replaced it with an Optima Red top. Cheaper than an oem battery and had a better warranty. Not sure on the model of the battery and it's not an exact fit. Had to make a small spacer between the top of the battery and the hold down bracket to make sure it didn't move around.
Old Dec 20, 2013 | 07:05 AM
  #236
noodlesandsam's Avatar
noodlesandsam
Feb 2005 production car. Battery lasted 5 years exactly. Replaced with oem. - not having a battery vent worried me, as this lives in the trunk of the s models
Old Jan 28, 2014 | 03:12 PM
  #237
4G0tten's Avatar
4G0tten
I just replaced the original battery in my 2004 MCS. I have just over 150,000 miles on the car. The stamp on the negative terminal was 01/04 which was the same week as when the car was built. So the battery lasted ten years and three weeks. I think the relatively few hot summer days in Michigan helped keep the battery alive longer.
The battery failed to start the car when the temp was 0F, but after putting it on the charger for a few hours it fired right up. I didn't want to take a chance so I replaced it so it wouldn't leave me stranded in the bitter cold weather we are having this week.
Here are some pictures of the battery I just replaced, including a crop of the date stamp on the terminal:
Attached Thumbnails How long did your OE battery last?-img_0973.jpg   How long did your OE battery last?-img_0973-001.jpg
Old Jan 28, 2014 | 04:02 PM
  #238
56 Blue's Avatar
56 Blue
Last night after work it just barely started. After it was running I noticed that all the clock digits were _ _ _ _ so I reset the clock.
It was -10F this morning. After work I needed a jump start.
Got a Maxx Everstart H6 at Walmart for $114. It's about an inch longer than the OEM battery, has 780 CCA but there is plenty of room in battery compartment and it has the vent connection. There is a lot of confusion on the interweb about how big the H6 battery is. It is 11" long, 6 7/8" wide and 7 1/2" tall. It is also cheaper than the H5 and has more CCA. The OEM battery is rated at 540 CCA.
I'm going to hook my battery charger to the terminals under the hood so the car does not know that the battery is being disconnected. That way I don't have to retrain the windows and other stuff.
Old Jan 28, 2014 | 04:21 PM
  #239
spirit16's Avatar
spirit16
9 years
I have a 2004 MCS and I just replace the battery a few months ago, so put me down for 9 years (build date March, 2004).
One interesting note. I was at a store, came out and the car would not even turn over. The battery was absolutely dead with no warning (like slow starter turning over...). Jumping the car from an SUV also did not turn over the starter. Eventually, I push started the car and off I went. Got home, went to AutoZone and picked up a replacement, installed it and all is well again....
Cannot complain when you get 9 years from the OEM....
Old Jan 29, 2014 | 06:10 AM
  #240
buzzsaw's Avatar
buzzsaw
quote: "I'm going to hook my battery charger to the terminals under the hood so the car does not know that the battery is being disconnected. That way I don't have to retrain the windows and other stuff."
Great idea! Thanks
Old Jan 29, 2014 | 01:49 PM
  #241
bcgreen's Avatar
bcgreen
Still going on my original battery on my MC40.
Question, where is the battery?
Old Jan 29, 2014 | 01:58 PM
  #242
BRGPA's Avatar
BRGPA
Mine is still the original- in service since October, 2002. I had it tested and the cranking is about 55% of original. Still putting out proper voltage. I'm considering a Diehard AGM from Sears- $165.
Old Feb 1, 2014 | 07:41 PM
  #243
db130's Avatar
db130
This is great information that you're sharing. More CCA/cheaper/vented/Johnson Controls made - this is a home-run.
Old Feb 1, 2014 | 07:47 PM
  #244
Raven Mocker's Avatar
Raven Mocker
My 2005 MCS still has the original battery.
Old Feb 2, 2014 | 07:37 AM
  #245
IQRaceworks's Avatar
IQRaceworks
Yep, mine too. Right around 8 years before it finally just died.
Old Feb 2, 2014 | 09:52 AM
  #246
cubiclegnome's Avatar
cubiclegnome
I replaced the OE battery last week on my 04 MCS. I'm not 100% certain it was the original, as I bought the car used. If so, that puts it at 10 years and 70,000 miles.
Old Feb 2, 2014 | 02:03 PM
  #247
Jimbo's Avatar
Jimbo
I got a Diehard to replace my OEM when it died after 5 years, it was shorter than the OEM and I ended up putting a 1/2" thick piece of foam board under it to make it tall enough for the cables to reach, then it only lasted 4 years and I had to replace it last month....went with an interstate this time and took out the filler because it was the OEM size.
My MiNI is an '06 R50.
Old Feb 3, 2014 | 06:22 AM
  #248
BRGPA's Avatar
BRGPA
The Diehard I'm looking at is a Group 47 which should be an exact replacement in my '03 S. It's the same size as the Autozone, NAPA, and Advance batteries that are also recommended as exact fit replacements. Guess I'll measure my actual battery to see if that's correct.
Old Feb 4, 2014 | 03:36 PM
  #249
findude's Avatar
findude
We're at 8 years, 5 months on the original battery. Still works fine.
Old Feb 7, 2014 | 05:57 PM
  #250
ArmyDog's Avatar
ArmyDog
Coordinator::Asia
9 years on the OEM battery on my 2004S. Not bad in Korea with the cold winters for the past years. I replaced it with an Atlas with cold cranking amp battery.
