R50/53 Calculating true speed (warning, math inside)
Old Jun 8, 2007 | 10:28 AM
  #26
kristina's Avatar
kristina
I'll admit that all this math is making my head hurt. So here's my stupid question. I assume the speedometer error affects the odometer. How, then, is gas mileage calculation affected?
Old Jun 8, 2007 | 10:36 AM
  #27
dwjj's Avatar
dwjj
I wouldn't be sure the odometer is affected as much. The manufacturer wants to make sure the speedometer never will read low, so adds some fudge factor for variance. It would look bad if a certain car started getting lots of tickets because the speedometers err in the wrong direction. The odometer doesn't have the same problem.
Throw in mileage calculations then you have to have fuel flow. There'd be some variability in that too. Not just measuring fuel, but things like temperature/expansion. It's amazing they can end up with a calculation within a few percent.
Old Jun 8, 2007 | 10:52 AM
  #28
markjenn's Avatar
markjenn
Yes, it's been documented that even when the speedo reads high, the odometer is usually more accurate. This is attributable to the regulations that require the speedo never read too low, so the mfgs build-in a design bias which seems to average about 5-7% high. The odometer, OTOH, is spec'd as a +/- couple percent tolerance, so it is usually pretty close.
Honda just lost a class action suit on odometers that read too high. They were within regulations, but Honda was deliberately biasing them a couple percent high to have warranties and leases expire prematurely. Soapbox: Of course, the lawyers got about $9M in the settlement, while the car owners got small extensions to their warranties and leases. All paid for, of course, by the folks buying new Hondas.
- Mark
David.R53
Sep 1, 2015 06:49 PM
I_drive_slow
Aug 18, 2015 10:47 AM
xpunisherx
Aug 10, 2015 10:50 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
