Navigation & Audio Stream audio without Connected?
Old May 21, 2012 | 01:47 PM
skotsour's Avatar
skotsour
Is this possible? I do have the Bluetooth connected to my phone (Nokia Lumia 900). Is there some sort of adapter or something available to be able to stream audio? I'm currently using the aux jack, but would love to get rid of some wires...
Old May 21, 2012 | 04:36 PM
chrunck's Avatar
chrunck
Pretty sure the answer is no. You could get an FM transmitter, but that has its share of wires.
Does it have to be from your phone? Have you considered a USB drive? That's obviously not an option if you're trying to use Pandora, but if you're just playing music stored on your phone, a small USB drive is the way to go.
Old May 21, 2012 | 06:37 PM
skotsour's Avatar
skotsour
Thanks for the reply. I probably will just go the USB route, but was hoping to be able to use the various music apps on my phone. I knew I shouldn't have talked myself out of Connected!!
Old May 21, 2012 | 07:17 PM
Kispian's Avatar
Kispian
I posted this on the main countryman talk page but it applies
For me I bought this product...it is really not a bad price considering what it does. It pairs easily over bluetooth and then you are good to go. I have it in my value edition Jetta and it makes life easy and I can stream anything wirelessly over Bluetooth...It sounds decent too...plus it can charge your phone at the same time over its USB input, has a 3.5mm in if you have something an iPod, and you can make calls etc
http://www.amazon.com/FlexSMART-Tran...d_bxgy_e_img_c
Old May 22, 2012 | 06:31 AM
skotsour's Avatar
skotsour
Thanks Kispian, how does it work near cities, etc? I've had something similar for my old iPhone and the reception varied but that could very well be what I'm looking for...
Old May 22, 2012 | 06:39 PM
Kispian's Avatar
Kispian
I am in the Denver Metro area...but that doesn't compare to Chicago for possible radio interference...but it has not been a real issue with finding a station to broadcast to. It can be set to any frequency in the FM band so it is not limited to only the the low end so this helps too. You can also control the volume the unit broadcasts at for more umph. If push comes to shove it does have a 3.5mm out so you can stream to the unit and then have it pass through to the stereo...so the phone remains wireless.
Also realized I should put in the disclaimer...I do not work for Accessory Power, or receive any compensation for recommending them. Just an owner with a good experience so far. Hope this helps...
Old May 22, 2012 | 06:43 PM
skotsour's Avatar
skotsour
Awesome, sounds promising. Thanks for the info!
Old May 25, 2012 | 03:51 PM
skotsour's Avatar
skotsour
I found this and just placed an order. Has anyone used this? I'll let you know how it works when I get it:
https://www.icarkits.com/cars/MINI_C...AN_2011/BTUNVS
Old May 29, 2012 | 05:17 PM
skotsour's Avatar
skotsour
Got it today. My initial opinion is 'meh'. Volume is very low even with phone volume and stereo volume jacked way up. I'll give it a few days of fiddling and see how it goes...
Old Jun 16, 2012 | 01:22 PM
Stb1115's Avatar
Stb1115
If you have an audio jack, you can buy a 3.5mm Bluetooth Receiver and plug it into the jack. Search "3.5mm bluetooth receiver" at Amazon. I still use the cables, but am thinking about trying one of these to stream wirelessly. The fact that Mini didn't build this into the Bluetooth makes me scratch my head still.
Old Jun 17, 2012 | 08:00 PM
carramrod's Avatar
carramrod
This product is quite good and works well with my Lumia 900 over bluetooth.
http://diceelectronics.com/media-bridge-info
Old Jun 18, 2012 | 03:05 AM
skotsour's Avatar
skotsour
Ive been eyeballing he MediaBridge. It's definitely on my wish list...
Old Jun 19, 2012 | 07:09 AM
skotsour's Avatar
skotsour
I ordered this today and should have it tomorrow. Was it a pretty straightforward install?
Old Jun 19, 2012 | 07:13 AM
carramrod's Avatar
carramrod
Yea, plugs into the CD changer port in the boot of the car, route the cable to the glovebox and route the microphone to the grill in the headliner (I moved the mic grill to the drivers side).
You might want to get some ferrite clamps from Radio Shack to help with lowering noise over the long cable run.
Old Jun 19, 2012 | 07:43 AM
skotsour's Avatar
skotsour
Awesome, thanks!
Old Jun 19, 2012 | 08:25 AM
teebo7's Avatar
teebo7
where did you guys end up buying these from?
Old Jun 19, 2012 | 08:30 AM
carramrod's Avatar
carramrod
Think I got mine off of Amazon. Pretty sure I did.
Old Jun 19, 2012 | 08:37 AM
teebo7's Avatar
teebo7
one last question, what's the model number? having issues with the Dice website right now.
thanks
Old Jun 19, 2012 | 09:06 AM
carramrod's Avatar
carramrod
thanks
MBR-1500-BMW
Amazon Amazon
Old Jun 19, 2012 | 09:11 AM
teebo7's Avatar
teebo7
thanks
Old Jun 19, 2012 | 09:27 AM
carramrod's Avatar
carramrod
WAIT!
I just checked DICE's site and they say it's not compatible with the Countryman. So I can't garuntee that it will work, mostly because I didn't realise I was in the Countryman forum. SORRY ABOUT THAT!
Edit: I feel like an ***. Really sorry!
Old Jun 19, 2012 | 09:48 AM
skotsour's Avatar
skotsour
Mine will be here tomorrow, so I'm still going to give it a whirl and see if it works. If not, it's easily returned through Amazon, so I'm not too worried about it...
Old Jun 19, 2012 | 11:03 AM
teebo7's Avatar
teebo7
it doesn't state it's compatible with newer Mini's can anyone confirm this?
Old Jun 21, 2012 | 05:13 AM
skotsour's Avatar
skotsour
Well, I can definitely confirm it does not work with a 2012 Countryman. I received it yesterday and there's just no way to make it work that I could see.
Old Jul 24, 2012 | 01:55 PM
Stb1115's Avatar
Stb1115
Just bought the GoGroove Bluetooth receiver that plugs into the 3.5mm plug. It's very small and is supposed to last 12 hours on the charge. Out of the box, a very good product. The only downside is the charger is not a mini- or micros-USB.
Amazon Amazon
I am using a Griffin dual USB charger plugged into the front lighter socket and a retractable USB charger (versus the Mini-supplied Y-cable). I bought a ProClip mount that sits to the right of the CD slot.
