Navigation & Audio compatible cell phones
Old Jul 3, 2007 | 06:18 AM
  #26
Loony2N's Avatar
Loony2N
Originally Posted by MINImanicMan
cob666 -- So you don't have to enable your blue tooth on your cell each time you get into the car to pair it? I do, but that might be the age of my phone.
Chances are, if you have a bluetooth phone it has an option to allow automatic paring. Look in your options or set-up on the phone.
Old Jul 3, 2007 | 07:42 AM
  #27
TheBigNewt's Avatar
TheBigNewt
Originally Posted by Coffeeman
I took out the adapter in the console and replaced it with the rubber inser that comes with non-bluetooth armrests. Now has about 50% more room. I've found the snap in adapters to be pretty worthless in my X5. I used it once. Add to this the fact that there are only a limited number of phones that they make adapters for. The whole point of bluetooth is to not have to "plug anything in", although the snap in adapter does charge the phone, and use the MINI's external antenna.
How did you get the sleeve out of the armrest?
Old Jul 3, 2007 | 03:54 PM
  #28
jtl004's Avatar
jtl004
Anybody know if they have an adapter for the armrest that will fit a Moto RAZR???
Thanks!
Old Jul 3, 2007 | 04:11 PM
  #29
Drsms22's Avatar
Drsms22
I have the connecting sleeve. It works
I use a Nokia 6230i phone (about two years old but lots of features) and it has a sleeve made for it by BMW. BMW sleeves are like $150.00. My car came used with that sleeve so I bought that phone and it works great.
Old Jul 3, 2007 | 08:01 PM
  #30
Birdman's Avatar
Birdman
cob666 -- Must be the age of my phone. I've got a Motorola e815. I'm thinking of the LG8600. What phone do you have that allows you to continue a phone conversation on your cell when you get in your car and transfer it to your car's bluetooth?
Probably your "older" phone. I just picked up my mini, took me about 20 seconds to pair my Blackjack, and it works like a charm.
Old Jul 5, 2007 | 03:21 AM
  #31
MINImanicMan's Avatar
MINImanicMan
Turns out the bluetooth power on my cell phone was not set to "on" 100% of the time, which is what caused me to have to manually intervene in order to get my phone to pair with my car's bluetoogh (by turning on the power). Works like a charm now.
Old Jul 5, 2007 | 04:47 AM
  #32
Coffeeman's Avatar
Coffeeman
Pops out
Old Jul 5, 2007 | 06:12 AM
  #33
MINImanicMan
To remove the sleeve from the armrest, pull the cover of the armrest back to the full open position. Then, you're supposed to be able to pull it back a little further (straight back, not up or slanted). At that point, you are supposed to be able to pull the front part of the cover of the armrest upwards slightly so that the cover is now slanted backward (while the armrest itself remains level). This gives you the access to slide the adapter backwards, out of the "plug", and then lift it out.
That's how the service manager described it to me, at least. My insert/adapter for my Motorola e815 is still on order so I haven't been able to test this thoroughly.
Old Jul 5, 2007 | 09:28 AM
  #34
Birdman's Avatar
Birdman
Minimaniac, you are referring to the phone adapter being removed which is made to come in and out. They/we are talking about removing the entire lining inside the compartment. The part that you slide your adapter into (when you get it), to make more room.
Coffee,
Do you think you would be able to buy a replacement insert after destroying it to get it out, and re-install it ok? I am thinking I will remove it/destroy it, if I could replace it in the future assuming someday I might get a "compatible phone with adapter"... what d oyou think?
And, could you post a pic of what the cable(s) look like?
Old Jul 17, 2007 | 07:35 AM
  #35
minikimme's Avatar
minikimme
Last edited by minikimme; Jul 17, 2007 at 08:54 AM. Reason: I posted a main thread as I need info quickly :)
Old Jul 19, 2007 | 11:26 PM
  #36
peter314's Avatar
peter314
it dosen't fit in the arm rest but my Samsung A900 works perfect. it sycns in like 5 seconds when i get in the car.
Old Aug 26, 2007 | 08:07 AM
  #37
Sowellman's Avatar
Sowellman
It's a BMW part, number 84210415023. You can find it here:
http://www.wireless4bmw.com/snapin.html
Old Dec 19, 2008 | 04:23 PM
  #38
MiniJma's Avatar
MiniJma
Blue tooth at last
Thanks for your list of compatible cell phones. I got the newer razr V9 and it works like a dream. My nightmare is over and my old cell phone is on Craig's list. Thanks for your post.
I just spoke with the service department at my MINI dealer. He said that the only people who can find the list of compatible phones on line are those who work for MINI and have special access. But, the list of compatible phones he gave me over the phone is below. This list is ONLY for cell phones on the Verizon wireless network. I hope this helps some.
You will need to call your dealer directly for other carriers:
Motorola Q
Motorola Razr V3
Blackberry 7130
Motorola E815
The "new" motorola Razr (I'm not sure which one this is, though)
Trio (not sure which model)
Motorola V330 (he called it the V thirty-three zero)
OldElvis
Oct 5, 2015 07:31 PM
GoBadges
Oct 1, 2015 11:10 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Oct 1, 2015 08:55 AM
