Navigation & Audio Help with panel removal...
Old Mar 20, 2007 | 09:07 PM
davisflyer's Avatar
davisflyer
Ok, so to those who know how to take your MINI apart: I'm trying to install an aux input and I need to get behind the radio. How do you remove the panel above the knees and below the steering wheel? I can't see any screws.
Old Mar 21, 2007 | 12:51 AM
btallack's Avatar
btallack
I posted a thread earlier today asking the same question:
https://www.northamericanmotoring.co...ad.php?t=95550
The short answer is that it pops down but it takes a scary amount of force to do so. It hinges on the bottom and has a clip on either side of the top that holds it in. I managed to push mine down from the space just below the steering column.
Old Mar 21, 2007 | 12:28 PM
DarrenO'sideCA's Avatar
DarrenO'sideCA
I found that it makes it easier if you put the tilt wheel in the highest position and stick your hand between the column and the panel. Pull hard down towards the floor. It'll go.
Old Mar 21, 2007 | 12:32 PM
shankrabbit's Avatar
shankrabbit
Don't be scared of the force or the sound it makes... it's made to pop down.
Old Mar 21, 2007 | 08:27 PM
davisflyer's Avatar
davisflyer
Thanks guys! After pulling down the panel, it took all of 15 min to install the aux. input!
Old Mar 21, 2007 | 08:29 PM
shankrabbit
Whooo Hoo!
Where did you mount it?
Old Mar 21, 2007 | 10:40 PM
davisflyer's Avatar
davisflyer
I had it come strait down the center console and it comes out centered underneath the toggles.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
