Navigation & Audio AMP INSTALL
Old Mar 11, 2007 | 08:41 PM
hugh's Avatar
hugh
AMP INSTALL
Has anyone put a small amplifier like the Alpine MRP-F250 in the right hand cubbyhole in the boot of an MCS where the Harmon Kardon amp would have been?
Is it diffucult running the cables back from the head unit?
Or am I better off placing it under the front seat?
Old Mar 11, 2007 | 08:54 PM
DOPAMINE's Avatar
DOPAMINE
the only issues i had with runnin cable was taking all the pillars of. unless your going for the snake under the carpet route.
Old Mar 12, 2007 | 01:06 AM
mikeythemini's Avatar
mikeythemini
I used to fit kenwood amps in there until they increased the size. There are existing nits in there that you can use for mounting. Cables are easy, just release the sill trim - 1 t50 torx for the seatbelt then its clipped into place
Have a look in the gallery at www.newministuff.com for some amp pics
Old Mar 12, 2007 | 01:49 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Under the front passenger seat is quite a bit of space for an amp.
Much better than the smaller area on the sides of the boot.
Old Mar 22, 2007 | 12:20 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
If you find an amp small enough to fit in, it would be possible.
Check my sticky thread in this section to knwo how to run the wires.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
