Navigation & Audio Front Speaker Rec's Needed
Old Feb 12, 2007 | 07:23 AM
ProfessorDave's Avatar
ProfessorDave
Hi all,
Even after doing several searches on this topic, I'm still confused about choosing a replacement for my lower front (non H/K) speakers (the p-side is blown). I'm not an audiophile, but do occasionally like to crank it up a bit. So what I'm after is:
-An easy install
-No need for an amp
-Not too outragious in price
Any advice would be great.
Thanks!
Dave
Old Feb 12, 2007 | 11:47 AM
scooterboy's Avatar
scooterboy
Unless you're going to amp it, I'd get an OEM replacement from your Mini dealer. The OEM speakers are only rated at 15w IIRC, and any aftermarket speaker will be rated much higher than that and thus won't perform that well with the stock head unit.
I'd put a WTB in the Marketplace forum. Maybe someone who's replaced their system will sell you an OEM speaker for cheap.
Old Feb 12, 2007 | 12:11 PM
ProfessorDave
That's a good tip scooter...I'll post over there.
Other thoughts? I know I've seen posts about Polks, Alpines, and others...
Old Feb 14, 2007 | 10:26 AM
hugh's Avatar
hugh
Many Mini owners have been very satisfied after upgrading to un-amped aftermarket speakers. Do a bit of research here on NAM and you'll find Infinities, Polks, and Alpines being driven by the factory head unit without adding an amp. These are inexpensive (under $100), high effeciency (91-93db) speakers. Owners claim that they provide a signifcant improvement over the stock speakers.
Old Feb 14, 2007 | 10:42 AM
scooterboy's Avatar
scooterboy
True, he can certainly do that. But the aftermarket speakers will not perform as well as they would if driven at the wattage they were designed for.
Old Feb 14, 2007 | 11:44 AM
JPMM's Avatar
JPMM
I'll be looking to do a speaker upgrade also. If you look at the effeciency's and keep the numbers high the stock non HK unit should work just fine. Is there replacements for the little tweaters on the doors too?
Old Feb 14, 2007 | 11:54 AM
kapps's Avatar
kapps
The only caveat is the MINI's non-HK speakers are 5 ohm instead of the normal 4 ohm. Putting a 4 ohm speaker on a receiver that's designed for 5 ohms will cause it to run hot and possibly destroy itself.
Old Feb 14, 2007 | 12:32 PM
hugh's Avatar
hugh
I've been reading the NAV Forum since Feb '05. I must have missed that.
All of the major brands offer a low end woofer/tweeter set in addition to their more expensive pairs of components that would need amping.
Old Feb 14, 2007 | 09:32 PM
JPMM's Avatar
JPMM
Maybe a 1 ohm resistor with a 4 ohm speaker to make 5 would do the trick?
Old Feb 15, 2007 | 05:45 AM
cristo's Avatar
cristo
Alliance Member
5 ohm and 4 ohm rated speakers are close enough to be considered
interchangeable. The impedance actually varies quite a bit at different
frequencies for all speakers.
Old Feb 15, 2007 | 07:54 AM
JPMM's Avatar
JPMM
I was wondering about that.I'll be looking for a set of speakers nothing like Polks or Infintitys- the expensive ,presise speakers seem to demand more power. I think something loose,cheap and efficient will still be better than stock.
Old Feb 15, 2007 | 08:19 AM
JPMM's Avatar
JPMM
Are there Mini venders that have addressed the replacement speaker situation? Crutchfield does not list the Mini's speaker replacements .
Old Feb 15, 2007 | 10:30 AM
cristo's Avatar
cristo
Alliance Member
Try starting here, it worked for me:
http://www.crutchfield.com/S-BH5fTvX...pFwEAN*l5TjN99
Old Feb 15, 2007 | 11:00 AM
JPMM's Avatar
JPMM
But if you have a non HK with Nav, no speakers come up, why is that? What does the Navigation system have to do with speakers?
Old Feb 15, 2007 | 11:24 AM
cristo's Avatar
cristo
Alliance Member
Dunno, I don't have Nav.
Anyone else know?
Mini'mon
Aug 26, 2015 01:02 PM
Minibeagle
Aug 13, 2015 10:00 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
OutMotoring
Aug 6, 2015 09:32 AM
