Navigation & Audio OEM iPod Adaptor
Old Dec 15, 2006 | 05:33 PM
jody's Avatar
jody
OEM iPod Adaptor
Anyone have the wiring diagram for the factory IPod adaptor that hooks into the head unit.
Old Dec 15, 2006 | 08:27 PM
200-OK's Avatar
200-OK
Do you just need the pin outs for the unit? Or are you looking for something different?
The install instructions, containing pin outs, can be found here:
http://www.motoringfile.com/files/mi...structions.pdf
Old Dec 15, 2006 | 11:32 PM
jody's Avatar
jody
Thanks...Just what I needed.
I think that may be what is causing my problem with my XM & Blitzsafe not workign. I'm going to uninstall the IPod adaptor and see if the xm works
Old Dec 16, 2006 | 06:05 AM
200-OK's Avatar
200-OK
Ahhh...., well good luck with that!
Old Jan 29, 2007 | 09:00 AM
thatatvguy's Avatar
thatatvguy
I have a question about the OEM iPod adapter and the Blitzsafe SLD01 kit.
I have read that the OEM adapter will not work with the SLD01 kit. Fine, but I ran accross somwthing this weekend.
Since I had started with the OEM kit and it "splices" into the harness, it is semi-permanent. OK, but the object was to get XM to work.
That being my goal, I caught a deal on the SLD01 kit. While installing it, I noticed that I could leave the iPod unit plugged in and the only thing I have to change is the audio that goes from the rear of the car. XM works!
Going one step farther, I pushed the mode button on the HU and changed from the XM back to the iPod. Controls are there, but no audio. So, I unplugged the audio from the XM and plugged the iPod back in - voila - it works.
So, my question is this: can I make some sort of switch that could "swap-over" the audio when I want to listen to the iPod vs. the XM?
ej
Nov 17, 2015 09:21 PM
quality_sound
Sep 12, 2015 05:55 PM
Ladybug-S
Sep 10, 2015 07:08 PM
Filmy
Sep 7, 2015 11:27 AM
Ntety
Sep 2, 2015 08:39 PM
