Navigation & Audio JL Audio Stealthbox/amp how-to
Old Aug 28, 2006 | 08:57 PM
weezer2282's Avatar
weezer2282
I searched the forums and couldn't really find anything on how to install a sub and amp. I'd like to install a Stealthbox and a JL audio amp to power it. What's the best way to get power and how does one wire it up?
Old Aug 28, 2006 | 09:51 PM
totamdu's Avatar
totamdu
Well its most like any other sub/amp combo. Battery is right there for power. You have to run it up front if just a mc. You can ground anywhere. For inputs the easiest thing to do is tap your rear speaker inputs. It sounds like a pain but once you get over the fear of ripping out the rear side panels and seats, and just do it, its easy. The remote wire runs up to the fuse box. I bet I could put a sub/amp combo in a mini in under an hour now. First time it took me a few. Nothing out of the ordinary, just a different car.
hope it helps
nypepper's Avatar
nypepper
power
you can get power from the battery easily if it's a mcs
Old Aug 28, 2006 | 09:52 PM
nypepper's Avatar
nypepper
i was too slow
what he said
Old Aug 29, 2006 | 05:08 PM
weezer2282's Avatar
weezer2282
It is a MCS. I figured getting the power from the battery right there would be pretty simple.
Which wire would be tapped into from the rear speaker for signal? Is it possible to tap into the cd changer wiring in the rear?
Old Aug 30, 2006 | 05:45 AM
soilsample's Avatar
soilsample
Do you have HK in your car?
If you do... this link will help
http://claire.shankrabbit.com/
If your car is non H/k you could pull one of the 6X9 speakers from the rear pannel and tap into the wires there for your Line out converter.
If you're looking for a source of "remote" power to turn the amp on ANYTIME the car is on, you could tap into the 12v socket in the boot. I think the middle wire on the 12v socket is switched on and off with the key.
I don't know about the non HK cars.... but with the HK you can turn the radio on without the keys..... if this is the case with your car, you wouldn't be able to turn on the amp/sub without the key.
Good luck
Old Aug 30, 2006 | 08:08 PM
weezer2282's Avatar
weezer2282
Good luck
It's a non HK. Since it seems like I will have to remove body panels I think I might turn this into a longer project and do some sound deadening too.
Thanks for all the help so far. Keep it coming.
Filmy
15
Jun 6, 2023 06:27 AM
gar56
Nov 15, 2016 06:41 AM
Chimera
Sep 30, 2015 02:53 PM
Filmy
Sep 7, 2015 08:27 PM
