Navigation & Audio aux install question
I'm wanting to install this aux input, but I want to know how to get the dash panel off - the one below the steering column. I need to pull it in order to get to the top torx bolt on the left downtube. The car is an '06.
thanks
bill
thanks
bill
Just sit in the seat and with both hands PULL down hard to release the snaps. that's all there is to it. From there, you have to wiggle the panel up and down to release the j hooks molded into the plastic that connect to plastic rail under the dash...it should only take a few seconds.
OutMotoring.com: Home of the finest MINI Parts + Accessories.
Shop online at www.OutMotoring.com
I use a wide flathead screwdriver at the two points where the tabs are, it is an act of faith the first dozen or so times. I went off the links in the MINI2 FAQ DIY section; it one of the few interior peices tht is the same after the 04/05 panel adjustments.
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
squawSkiBum
Oct 2, 2015 09:21 AM
