Navigation & Audio New info on DICE Electronics iPod adaptor
Old Jan 1, 2007 | 03:51 PM
  #401
dbert4's Avatar
dbert4
Originally Posted by Keyne
Just got the DICE T for Christmas and looking at what I received looks different than the connectors in any of the install manuals online...
I have the DICE unit, the IPOD connect and those make sense to me, but there is a cord and with two black larger box type connectors attached to an insultated cord... looks like you plug both of those together (male and female) and then insert the 3 and 6 pin MINI connectors into the white connection on one of these pieces? Did anyone else get this in their kit? Not sure where to plug the MINI CD Changer connection into and just want to make I dont screw this thing up. Anyone have pics they can share on how it should look? Help if you can.
KD
BTW - No Nav, no CD changer, no HK. Just stock setup with multifunction stearing wheel.
What they sent you is the radio harness not the trunk harness, same thing happened to me. What you do is remove the 2 side pillars and the 4 screws which hold the radio. Carefully remove the radio, there is a little cable which is the antenna which needs to be romoved carefully. Unplug the factory harness and insert the harness that they sent you into the middle. Since you don't have NAV you would be finished. Put it back together.
If you had NAV you need to move a connector to jumper the NAV voice back to the radio and the text wouldn't work any longer if the NAV is being used. Good luck!
Old Jan 1, 2007 | 04:10 PM
  #402
rkw's Avatar
rkw
Do you have NAV? If so, please describe the operation. How easy is it to switch between NAV and text on the screen? When you use NAV, does any text display on the head unit?
Edit: I found your earlier post. Did you have any resolution to those issues?
Old Jan 1, 2007 | 09:55 PM
  #403
tom @ eas's Avatar
tom @ eas
Thanks for the quick response! Yep, those are the connectors I have... Bummer I wanted to mount it in the trunk not up front. I guess i will have to send back the cables i have and get the ones for the trunk. My plan was to mount it in the trunk to the cd changer cable and just keep the Ipod mounted behind the panel out of sight. Just control everything from the HU or the steering wheel.
The iPod should be up front with you - it makes the kit MUCH easier to use if a passenger is with you or connecting/disconnecting the iPod without going to the boot every time.
If you prefer the trunk interface kit, we can provide the wiring also.
Old Jan 5, 2007 | 10:34 AM
  #404
thirdraildesignlab's Avatar
thirdraildesignlab
Hey there
I was one of the early adopters for the DICE unit, and have loved it since day one. That said, I noticed some new behavior this last week. Text display disappeared. Anyone see this happen? 06 MCS. I did have the Parrot EVO kit and MFSW adapter put in, but it WAS working flawlessly after that... until now.
I've been doing a bit of trial and error to see if i can get the text back...
Anyone see this behavior?
Oh, no nav, BTW.
Old Jan 5, 2007 | 10:57 AM
  #405
tom @ eas's Avatar
tom @ eas
Originally Posted by thirdraildesignlab
Hey there
Oh, no nav, BTW.
There was a similiar problem on an X3, when a Bluetooth call came in, the text was cleared. Can you confirm on your end?
In the meantime, this has been resolved with a firmware fix.
Old Jan 5, 2007 | 11:51 AM
  #406
Deuce_Coop's Avatar
Deuce_Coop
Ok UPS just dropped off my dice unit and, as per the instructions, went to the Denison USA website for detailed install directions and got this
http://www.densionusa.com/
Old Jan 5, 2007 | 11:57 AM
  #407
tom @ eas's Avatar
tom @ eas
Dension and DICE are two different companies. Where was the kit ordered from and did you receive a Trunk interface or Radio interface kit?
Old Jan 5, 2007 | 12:02 PM
  #408
Deuce_Coop's Avatar
Deuce_Coop
It was ordered from diceelectronics in Lake Tahoe, NV. As far as interface goes, i'm assuming it is the trunk kit as the cloth wrapped cables are about 15 foot long.
Old Jan 5, 2007 | 12:26 PM
  #409
tom @ eas's Avatar
tom @ eas
Your connections will be in the boot area on the passenger side. Simply connect the 3/6 pin connectors and route the cable where you would like the iPod to reside.
Old Jan 18, 2007 | 11:03 AM
  #410
randers51's Avatar
randers51
Hey there
Oh, no nav, BTW.
I had this same problem with my first DICE HD module. I had to return it for a replacement unit. The problem is heat related on the units with the firmware version of HD0001. I have a new one and it seems OK for now. Just dealing with a bad hum when connected to the iPod.
Old Jan 18, 2007 | 11:08 AM
  #411
tom @ eas's Avatar
tom @ eas
We're crossing threads - there's a response for you on post #44 of this thread:
https://www.northamericanmotoring.co...=1#post1325551
Old Jan 18, 2007 | 11:14 AM
  #412
thirdraildesignlab
On my end (again, DICE (version 2 replacement module) with Parrot EVO and MFSW integration kits, stock radio, no changer, no nav)
the situation is reasonably normal playing, navigation and interfacing behavior with the Dice, but simply that the text tags disappeared.
I do see a message on the radio when the BT phone is in use, but then it just returns to whatever was on the radio before, either FM, CD or the 'Track XX' of the DICE's info, whatever that happened to be. But no more text tags. I'm trying to understand if it's a DICE problem or not...
I've pulled and reconnected the DICE module, still no text. Before I head back to my stereo installer, I thought I'd contnue researching it...
Old Jan 18, 2007 | 11:40 AM
  #413
tom @ eas's Avatar
tom @ eas
Answered in Q/A thread: https://www.northamericanmotoring.co...=1#post1325599
Old Jan 18, 2007 | 12:04 PM
  #414
thirdraildesignlab
Yep. I'm an idiot.
I, or my wife, must have mashed CD06 button at some point, diabling text.
All's better now!
Once again, i highly endorse the DICE product. Love it.
Old Feb 27, 2007 | 08:01 AM
  #415
lintqueen's Avatar
lintqueen
Had ICElink, seems broken, need replacement - help!
I have an '04 Cooper (and I love it, of course) with the HK sound upgrade, and had installed an ICElink connector (the one that had an integrated iPod holder and was controllable by the steering wheel).
It seems to have gone kaput. My dealership checked the connections, etc. and says it seems to be the unit itself.
So, I need a replacement. From what I've seen on here it looks like the DICE is the best option (but am more than willing to entertain alternatives).
What I'd like (in some hypothetical universe) is:
  • my iPod held nicely for me
  • my song names on my radio display (no, the ICE didn't have this)
  • iPod charged automatically
  • iPod shut off when car is off
  • ability to control iPod via steering wheel (min: volume, songs forward and back, but other controls would be nice too)
I *think* I can manage the installation (I've replaced a head unit before, albeit in a Saturn).
I'd love some advice on (a) is DICE the answer (b) will it do what I want (c) exactly what do I need to buy (cables, mounting thingy [that's the technical term], DICE itself, others?) and (d) any recommendations on from whom.
Many thanks in advance!
Old Feb 27, 2007 | 10:35 AM
  #416
tom @ eas's Avatar
tom @ eas
Answered in DICE Q/A Thread: https://www.northamericanmotoring.co...=1#post1394883
Old Feb 28, 2007 | 10:09 PM
  #417
gosheshe's Avatar
gosheshe
You'll need a 4/2005+ for text display, but you will have full steering wheel control.
4/2005+ = what does this mean?
i'm bucking up and finally want to install an ipod adapter on my 02 mini.
can this be done with the stock head unit? a local audio shop said no way.
any recommendations on a professional install; i cant do it on my own.
ps i want to be able to use my steering wheel controls
Old Feb 28, 2007 | 10:16 PM
  #418
tom @ eas's Avatar
tom @ eas
This means you will need an April 2005 radio or later build for text display, your 2002 model is not compatible for text display. You will still have text display on the iPod and steering wheel control.
Old Mar 14, 2007 | 12:37 PM
  #419
S33BBY's Avatar
S33BBY
Hi everyone, just wondering if there's any update on getting the DICE to display text on the stereo properly with factory nav?
Old Mar 14, 2007 | 01:16 PM
  #420
tom @ eas's Avatar
tom @ eas
In development at the moment, we will report as soon as there is a solution.
Old Mar 14, 2007 | 01:21 PM
  #421
S33BBY's Avatar
S33BBY
Cool. I'm in the UK using a Dension ice>Link Plus. Dension can't seem to (or won't) do it, so I'll be very impressed if it can be sorted on the DICE, and I'll probably be looking at shipping one over.
Old Jun 19, 2007 | 08:27 AM
  #422
Red Scooter's Avatar
Red Scooter
Got my DICE yesterday for my '06! I read up on the radio removal and learned I only had to unscrew the down tubes to get to the radio mount screws! No gear shift, etc. removal!
Tom at aes has been awesome. Super fast (and patient) with responses to questions.
Anyway, I was trying to figure out the Album browse (with Tom's help) and I have a tip! It may already be here somewhere :impatient but it's a massive thread!
The Album browse, I learned, is from within a Playlist. Therefore, Tom suggested creating a playlist of your entire library. Here are the steps I took and what made it work best with the Album browse.
BEFORE you create the Playlist with your entire iTunes library (I named it "1st" to put it at the top of the Playlist list) sort the Album column alphabetically by clicking on the bar at the top of the column. (There are three options: Album, Album by Artist and Album by Year). Use the "Album" sort option.
In the car, when playing the "entire library " playlist, choose Disc 3 (Album browse option). When you choose "next track" it THEN goes to the next album. If you don't create your list per the abovve, it will go to the next track in the playlist. If you have an iPod Video, you can see that it jumps from Track 1 to Track 14 (for example).
Always fun to learn more about your iPod and DICE.
Old Jun 19, 2007 | 11:10 AM
  #423
dbert4's Avatar
dbert4
Let's be honest
Tom,
We've been hearing the same tired song about, help being on the way since almost a year from both you and Dice. The truth is that it's all "Vaporware".
You should be be honest and remove your claim about song title display on the Nav from the advertisements. Please no more bogus promises.
Old Jun 19, 2007 | 11:17 AM
  #424
tom @ eas's Avatar
tom @ eas
Tom,
Not true at all, but you'll hear when the problem is solved here on the forums.
Old May 3, 2011 | 04:36 PM
  #425
splat's Avatar
splat
Thinkin of picking up one of these for my 06 cabrio. Any current opinions on Dice?
