Navigation & Audio AUX input....not needed
This is my first post in these forums...
I read alot comments about how ther could be an AUX input in the upcoming models..
FM TRANSMITTER
this things sends an FM signal to the radio, so u could connect ur ipod or whatevr with much cable....
though not sure if its quality si that good, i think $90 is a good deal......?.......
FM TRANSMITTER
This is the Blitzsafe adaptor. It requires (I think) that you plug it in in the back of the mini to the CD Changer connections. Then if you wanted an aux input in the front (an mp3 player etc) you'd have to run a wire back up to the front, as well as get an adaptor to convert the RCA connections to a minijack connection. A lot of mucking about.
I'm waiting for the adaptor from Mini, now long long overdue. See the forums on miniusa owner's lounge.
PS: FM Transmitters are horrible in quality, at best only a temporary solution.
hawk2005,
Welcome to MCO!
An FM transmitter will work fine if sound quality is not important to you. But a digital music source, even MP3, has far superior sound quality to FM broadcasts; more bass, more highs, less distortion and noise. The same song sounds much better on a CD than when you hear it played on the radio right?
When you listen to the MP3 through the FM transmitter, the signal quality gets reduced to that of an FM broadcast. Since the signal comes from within your car, it will be as good as a very strong FM station, but no better.
A direct low-level connection will give much cleaner results from sonic standpoint (although not as easy an install). Either the Blitzsafe product through the MINIs CD changer hook-ups or the pending factory adapter will provide this kind of connection. The factory option, if it ever arrives, should be a very easy install as I believe it plugs into the back of the stereo in the dash and runs into the glovebox.
Cheers and good luck,
James
Welcome to MCO!
James
penguinhomey
38
Jul 7, 2019 09:24 PM
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Aug 12, 2015 01:24 PM
