Navigation & Audio iPod auxiliary?
Old May 16, 2005 | 01:51 PM
  #26
Doenut_1's Avatar
Doenut_1
Just got the auxilary input and installed into on Saturday. Works great on my iPod. No volume problems or anything. I even still have my 6 cd changer hooked up just in case i forget the pod at home. Also got the belkin car adapter and and belkin car holder is on its way. Ministeve7 you were a great help and thank you all.
Old May 18, 2005 | 10:05 AM
  #27
chrisneal's Avatar
chrisneal
Originally Posted by bee1000n
The sound is great out of the headphone jack, just need to turn the iPod up to about 80%, set the input level at +5 on the H/K head unit, and turn it up a little. I've found that setting the iPod's EQ to Electronic works nicely.
I always have my iPod on maximum volume in my car, and adjust the speaker volume using the head unit. My impression is that this maximizes the sound quality, but I could be wrong.
And I'll add in my encouragement to any "amateurs" who are squeamish about attempting to install the aux input - it's really easy, especially if you have small hands!
Old May 18, 2005 | 11:06 AM
  #28
Doenut_1's Avatar
Doenut_1
Mine stoped working after four days of use!!! I'm kind of upset
Old May 20, 2005 | 05:04 AM
  #29
jbiancolli's Avatar
jbiancolli
Originally Posted by oswald
Darn. The mini jack audio quality is *terrible* for car speakers as it it optimized for headphones. Does anybody else know of a solution that uses the real docking plug for the iPod?
try www.sik.com
plugs into port connector of ipod and works great.
Old May 20, 2005 | 05:55 AM
  #30
blalor's Avatar
blalor
Originally Posted by matthewz
If you don't have the space/inclination to use your dock in the car, try the PocketDock with line out, available at www.sendstation.com. Quality work, I used the original PocketDock for some time to charge two iPods of differing vintage with the same cable and cigarette lighter adapter.
I'm using two Belkin auto adapters. In our Jetta I've got a tape adapter plugged into it. In our Santa Fe, I'm using an aux input for the aftermarket Blaupunkt head unit. The Belkin provides a level-adjustable 1/8" output. It powers/charges the iPod and attaches via the dock port on the iPod; that's the only connection to the iPod. It works quite well, but I've got some alternator whine in both vehicles, which I've yet to investigate...
I've also got a PocketDock for use around the house and I'm very happy with that, as well.
Old May 29, 2005 | 07:18 AM
  #31
Call's Avatar
Call
IPOD car holder
In MINIsteve7's pic I noticed the cup doesn't fit so well in the cup holder. I purchased it anyway but could not get it to fit. Not very stable when trying to change things on the IPOD. Any better suggestions?
Old May 31, 2005 | 04:58 AM
  #32
cooper44's Avatar
cooper44
I installed the aux input on my 03, no problems. But now I have an 05 and I can't seem to get the plastic shield from under the steering wheel off. Do I pull from the top and have it pop out? If I remember correctly, the 03 had tabs and was easy to remove. I don't want to pull on this and break anything. Any advice would be appreciated! I have an iPod that I'd like to use when I'm driving! Thanks everyone.
Old May 31, 2005 | 08:52 AM
  #33
blalor's Avatar
blalor
You're referring to the so-called "bolster" under the steering column, in front of your knees? If you've got the stock one without the storage shelf, you should be able to just yank from the circular cut-out at the top. I've popped mine ('05, too) open several times, now.
Old May 31, 2005 | 04:49 PM
  #34
cooper44's Avatar
cooper44
That's exactly what I'm talking about! Thank you. I thought it would just pull out, but I wasn't sure and I didn't really want to break anything. All the best! Thanks!
Old Jun 2, 2005 | 10:13 AM
  #35
cooper44's Avatar
cooper44
As easy as the 03! Thanks again. Now I can listen to all of my favorite songs uninterrupted.
RobbyD
Jan 29, 2019 01:22 PM
pglgp1292
Aug 9, 2017 12:45 PM
gar56
Nov 15, 2016 06:41 AM
krohm
Sep 28, 2015 12:16 PM
Ntety
Sep 2, 2015 08:39 PM
