Navigation & Audio XM Roady Antenna Wire - Get unlocked door warning.
I have XM radio now (Roady). The problem with the Roady is the antenna wire. I have the wire going out the hatch back, antenna mounted on the rear of the roof. I keep getting a warning signal that my hatchback door is not closed securely - wow the sensor must be sensitive because the hatchback door closes just fine. Anyway to get around this? I have threaded the antenna wire every which way. I guess the Sirius plug and play unit will cause the same problem, right?
Thanks!
Thanks!
Thanks!
Thanks!
I pulled down the hatch gasket, pulled the antenna through and put the gasket back in place.
Maybe there is something else going on???
Originally Posted by Johnna
I've got a Roady antenna wire that goes out the back hatch and I have had no problem at all with the "hatch open" warning light.
Dec 23, 2015 10:36 AM
polotska
Aug 23, 2015 03:03 PM
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
Aug 17, 2015 05:09 PM
