Aftermarket + OEM radio wiring both on CAN Bus
Hey everyone! I have a 2012 R57 S with a regular (non HK) Boost CD radio system. I successfully installed a double DIN aftermarket radio with CarPlay/Android Auto thanks to all the folks on this forum.
I've read on other threads here that certain scans (DIS, ISTA) and dealer diagnostics/updates require the OEM radio to be present.
https://www.northamericanmotoring.co...ml#post3164010
To make this easier, I was wondering if there's some way I can have both radios connected to the CAN bus. It's simple to tap the wires, but the question is SHOULD I?
I called techs at both Crutchfield and Metra/Axxess and all said I'm in uncharted waters. Metra has done this before on Cadillacs, but never on European cars.
Not sure if I should even experiment doing this. Plan B is to wire up my own harness to glovebox so that it's easier to switch between the two radios. Any thoughts most appreciated!
Thanks! I'll post pics and stuff in another thread later.
If anyone has ideas on my original question though, about the risk/safety of wiring both radios on the CAN bus at the same time, most appreciated!
RebelYell260261
Nov 21, 2021 07:48 PM
Hbm097
Dec 23, 2020 07:22 AM
Navigation & Audio Connecting stock radio into AUX of aftermarket replacement
Geektb
Nov 12, 2012 06:29 AM
