More questions about EVO upgrade
Old Oct 3, 2020 | 09:48 AM
reidmefirst's Avatar
reidmefirst
Hey all -
A while ago I bought a NBT EVO and had it programmed for my vehicle's VIN. I also bought a 8.8" screen for a more or less complete retrofit (just no handwriting recognition wheel, but it seems that that is not required).
I'm finally getting around to installing it this weekend, but I have some questions.
I've pulled apart my dash and wanted to check the new screen, prior to removing my old computer. All of the cables connect into the new screen fine. When I turn on the radio, the 8.8" screen says "NO SIGNAL", but of course the buttons around the radio still work (my factory preset stations work fine, volume works, etc). Is this normal? I am wondering if I need to code the car to tell that it has a bigger screen, in order for the old head unit to be able to send a proper signal to the screen? Or does this mean that I need a new cable or something?
I just want to be sure that I have a working radio and screen prior to pulling out the old computer and stuffing in the NBT EVO...would be nice to know if verification steps like what I'm doing, are even necessary...
Thanks!
Old Oct 3, 2020 | 10:52 AM
sb2002's Avatar
sb2002
Originally Posted by reidmefirst
Hey all -
Thanks!
Hi. Is the new screen a touch screen? If so, your old headunit (which I'm assuming is an entrynav headunit, based on your car having come with the simple iDrive ****) cannot support it. Even if it is not a touchscreen, you'd need to make coding changes for it to work.
Best,
Steve
Old Oct 3, 2020 | 11:55 AM
reidmefirst
My 8.8" screen is not a touch screen. My current head unit is a 6.5" screen which IS a touch screen. Would it be normal to see 'no signal' for trying to swap in the 8.8" without doing any coding?
Old Oct 3, 2020 | 06:26 PM
hcube's Avatar
hcube
yes, you need to code it.
mragaban
Navigation and Audio
Dec 11, 2018 09:06 PM
03mini-S
F54 :: Clubman Talk (2015+)
14
Apr 5, 2017 02:47 PM
Winston46
Nov 3, 2015 06:07 PM
Guards Red Car
Nov 29, 2011 04:58 AM
swinburne
Jun 22, 2005 04:49 PM
