Navigation & Audio MP3s in 2005's
Old Mar 23, 2005 | 07:56 PM
  #26
atomtbomb's Avatar
atomtbomb
In regards to playing MP3s, will the 2005 head unit read through child directories? For example, if I create an MP3 CD with the folders arranged like so: Artist/Album/Trackname.mp3, will the headunit read them? Or will it only read 1st level directories?
Old Mar 24, 2005 | 05:27 AM
  #27
CARdiac's Avatar
CARdiac
Originally Posted by Ran48
I made the cd with Roxio also, but just as a data disk not a music disk. So basically your're just formating a cd and doing a straight copy of mp3 files to it. Again, at least for me, none of the tags display.
I burned the files as a data disk but it still gives me a CD error. Is there something wrong with my headunit?
Old Mar 24, 2005 | 05:38 AM
  #28
mmatarella's Avatar
mmatarella
Some more testing
I just took delivery of a 05 MCSC on March 18th.
I'll try some new MP3 cd's to see if I can figure this out. But FYI, CD's I already had on hand that DID show the tags in my AIWA aftermarket head unit in my van do not show the tags in the MINI. (Base CD system not HK upgrade). They do play fine. I also played one that's a CD-RW no problem. (Burned and closed, not DLA)
Old Mar 24, 2005 | 12:15 PM
  #29
CARdiac's Avatar
CARdiac
At this point I would be happy if they played the MP3 CDs... I just get an error and it ejects the CD
Old Mar 24, 2005 | 12:41 PM
  #30
stso's Avatar
stso
I made an MP3 CD of some audio books that I have and the MP3s play quite well on my HK head unit. It seems as if the unit only recognizes top level directories, no farther down. There was no ID3 info on the HU but that was OK since I already knew what was on the CD.
So the CD looks like
Top-level
* Album1
**** Track1
**** Track2
**** Track3
* Album2
**** TrackA
**** TrackB
**** TrackC
etc.
BTW, I used straight Windows XP to burn the MP3 CD, no iTunes, no MusicMatch, etc. Only issue is the file ordering, you should put numbers on your tracks because the head unit will play your tracks in alphabetical order if the numbers aren't present.
If you're CD-Rs don't play on all CD players, you're most likely looking at a bad CD recordable drive or a bad batch of CD-Rs.
ST
  #31
brgfan's Avatar
brgfan
Originally Posted by CARdiac
But yours played when burned as a data disk correct?
CARdiac, I don't know what kind of CD burner you have, but some burners are only successful, if you burn at the slowest speed (x2, or x4, or whatever). Some software will auto-select a speed that is too fast for the burner. You will get every indication that the burn was successful, but it won't play. There's a lot of trial and error involved.
Good luck.
Old Mar 24, 2005 | 12:52 PM
  #32
mikehoward's Avatar
mikehoward
I had no trouble in October last year playing mp3 and wma files off the root directory of a cd. Roxio and Nero have been used for these files as well as the Media Player cd burn utility. Quality of the cd does influence playability. Burner age also affects it.
Old Mar 24, 2005 | 01:12 PM
  #33
Itsdchz's Avatar
Itsdchz
Used OSX to burn my CD's, made folders with mp3's in each folder, numbered to play in my order and no problems, have about 200 mp3's on 1 CD. Sounds great, just no ID tags...
Old Mar 24, 2005 | 01:21 PM
  #34
CARdiac's Avatar
CARdiac
I have the NON- HK unit, does that make a difference?
  #35
Strom's Avatar
Strom
It will work, but the directories end up numbered strangely by the head unit. It would be like this:
"Number" | Directory Name
.. 2 ............ Artist1/Album1
.. 4 ............ Artist2/Album1
.. 6 ............ Artist3/Album1
.. 7 ............ Artist3/Album2
.. 9 ............ Artist4/Album1
They all play - they're just numbered strangely. Edit: Spaces get removed, so I had to use periods to create the table.
Actually, has anyone noticed that sometimes the head unit skips songs or puts them out of order? I've also had times when it goes silent for 30 seconds and then comes back. This has only happened to me with MP3 discs.
Old Mar 24, 2005 | 01:40 PM
  #36
plantain's Avatar
plantain
No, it makes no difference. I have a non-hk unit and my '05 head unit plays MP3 cds just fine. Just make sure you burn your cd using standard, track or disc-at-once methods (no packet method writing, which lets you treat your CD like a read/write disk), and close the session and disc once you're done.
Old Mar 24, 2005 | 01:53 PM
  #37
CARdiac's Avatar
CARdiac
That is what I did...darn!!!
Old Mar 24, 2005 | 02:05 PM
  #38
jaxkewl's Avatar
jaxkewl
i burnt my mp3's and wma's using a cd-rw using WMP and roxio. no problems. always burned at 4x. i do know that the non-hk unit will not play any songs that are protected. i have some songs i downloaded from napster and its protected and it will not play those.
hey, better than nothing eh?
Old Mar 24, 2005 | 02:21 PM
  #39
atomtbomb's Avatar
atomtbomb
Originally Posted by Strom
It will work, but the directories end up numbered strangely by the head unit...
...I've also had times when it goes silent for 30 seconds and then comes back. This has only happened to me with MP3 discs.
Thanks a lot for the info. I'm taking a trip tomorrow to go pick up my new MINI and I wanted to have a few CDs ready for the trip back.
Old Mar 24, 2005 | 03:14 PM
  #40
Strom's Avatar
Strom
Will yours play WMA files? Mine doesn't seem to like them...
Old Mar 24, 2005 | 04:01 PM
  #41
brgfan's Avatar
brgfan
I noticed that when I burned my first "project" to cd. I had multiple ablums by an artist grouped within a higher level directory/folder. When I burned the CD that way and put it in the MINI player, the player ignored the artist folders that contained the albums, but seemed to allocate a number to them.
For instance a folder called Neil Young contains After the Gold Rush, Long May You Run, and Rust Never Sleeps. The CD player seems to assign #1 to the Neil Young "top level" folder, and then ignores it, but it refers to After the Gold Rush as #2, Long May You Run as #3, and Rust Never Sleeps as #4.
Old Mar 25, 2005 | 03:36 PM
  #42
CARdiac's Avatar
CARdiac
I burned a CD on my laptop Vs the Desktop and it worked
Old Mar 25, 2005 | 04:00 PM
  #43
jaxkewl's Avatar
jaxkewl
yup, mp3's and wma's will play fine. only the non protected kind. u can tell if its protected by right clicking on the file and if there is a "license" or "protection" tab then it has protection.
Old Mar 28, 2005 | 10:56 PM
  #44
Strom's Avatar
Strom
They must've been protected.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Wombat Pie
Navigation/Audio
Oct 5, 2015 08:00 PM
bahman
Sep 30, 2015 01:59 PM
dutchhome
Sep 30, 2015 07:17 AM
yyj3869
Sep 28, 2015 06:53 PM
