Navigation & Audio Diagnostic Issues after Aftermarket Head Unit Replacement
Old Dec 24, 2018 | 07:31 AM
jpm569's Avatar
jpm569
I have a justa r56 and my radio died. I am thinking about replacing the headunit to an after market system as the dealer quoted by 2k.
I have read on various threads that replacing the stock headunit could lead to issues with diagnostics. Does anyone know this to be the case in reality instead of just conjecture? Has anyone been told that their car has cannot be serviced? I called two dealerships and they both said it wouldn't be an issues. The OBD will connect just fine. They said that the only thing is that the mini would be able to receive software updates which they don't recommend in a mini of my age anyways.
Thoughts?
Old Dec 24, 2018 | 09:20 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
My F56 has after market amp and the car has error codes if you scan it. I have had it in for service since install without issues. Not sure what would happen if other issues popped up on my car and dealership blamed my amp.
Old Dec 24, 2018 | 10:40 AM
jpm569's Avatar
jpm569
Do you get a dashlight on because that would really annoy me
Old Dec 24, 2018 | 11:00 AM
Minnie.the.Moocher
No idiot lights at all. Only a OBD scan with MINI level diagnostics shows all the errors of not having a factory amp. A regular free OBD app on phone doesn't show the errors. Keep in mind that I'm talking about an F series, don't really know how the R generation will work, but I suspect the same results.
Old Jan 1, 2019 | 07:55 AM
Skorpan's Avatar
Skorpan
My understanding is exactly the same, you just won't be able to update software. I have a 2009 D R56 with radio removed and double din installed. Have connected using a iCarsoft BMM V2.0 and it reads and clears codes without issue.
Hooligans
Apr 15, 2018 02:00 PM
Cudda_Kine
Nov 4, 2010 02:11 AM
DuNcE223
Feb 22, 2003 11:08 AM
