Navigation & Audio Roady2 XM
Old Aug 23, 2004 | 06:03 AM
  #26
JustinLewis's Avatar
JustinLewis
Just look for these wires in your boot. They will be located in the right pannel. If you have them im sure the XM direct will work. There is no need for the Comander
that are the ones all taped up laying there. Untap them and see if they are in there.
Old Aug 23, 2004 | 06:28 AM
  #27
ZAKdog's Avatar
ZAKdog
05 unit swap?
is it advisable to get the 05 head unit and call it a day? or is it not that easy?
an upgradeable car...who would'a thunk it?
Old Aug 23, 2004 | 09:00 AM
  #28
jtpryan
Right. I do believe they are there. But won't I still need the later head unit if I want the full display?
-Jim
Old Aug 23, 2004 | 09:02 AM
  #29
JustinLewis
-Jim
Im not sure on that. I have never seen a difrent display other than an 04. Sorry i cant help you in that area.
Old Aug 24, 2004 | 10:15 AM
  #30
jtpryan
Right, well I believe these are my options:
1.) Get the XM Direct with my current radio. ~$275
2.) Get a newer head unit used + 1.) ~$275 + $50 - $100??
3.) Get a Roady2. ~$130
With 1 I can use my MFSW, but no readout of artist and song.
With 2 I get everything.
With 3 I get artist and song, but no MFSW control.
So what I need to decide is MFSW control worth ~$150 or is the best of everything worth ~$200-->$250. I don't think I would use the unit outside my car, but that is a nice option with the Roady2. I'm thinking I might get the Roady2 and play around with it just to see if I like sat radio. I guess I can return it and go the other routes if I really like it.
Thanks for all the input.
Old Aug 25, 2004 | 03:23 AM
  #31
jtpryan
How long is the antenna wire...
...On the Roady2? Can I put it on the back of the car?
Old Aug 25, 2004 | 07:34 AM
  #32
Johnna's Avatar
Johnna
There is a remote control available for the Roady but I think it's an infrared line of sight kind of a unit so it wouldn't work on a hidden receiver.
I've got my Roady mounted on a power stalk that I jab into the under dash power socket. It's easy to move from car to car. Have a look at the attached phone cam pictures.
Old Aug 25, 2004 | 07:50 AM
  #33
xsmini's Avatar
xsmini
its worth it....
I had the Delphi for almost a year when I swithced to the XM direct. I like the look without extra pieces of radio equipment all over the dash area. I had a clean set-up but I found it annoying to have to reach down to change channels (much like I do when I drive anything but a MINI now ) If going with the roady/ delphi you have to use a modulator, because the head unit is foreign, some addition connections are needed to make it work correct (antenna adaptors). Because of this the sound quality with the Delphi was nowhere near as good as with the XM Direct.
If I were you I would by the XM-Direct kit and see if it worked with the 02 head, if it doesn't then upgrade the head unit to an 03.
Good luck,
Nik
benzamg
MINIs and Minis for Sale (archive)
29
Jun 7, 2008 08:25 PM
miniclubman
R55 :: Clubman Talk (2008+)
Mar 23, 2008 04:44 PM
mshaw
Jun 27, 2006 10:44 AM
stylin99
Jul 29, 2005 02:34 PM
muidaq
Nov 7, 2004 01:23 PM
