Navigation & Audio Adding a sub to a HK unit
Hi all,
I have the HK system in my mini. All things considered, I've been pretty happy with it. However, the other day, a 10-inch sub and an amp fell into my lap. Is there any problems w/installing a sub into a HK system? I did a search and I'm not sure what I read... Sounds like it can't be done easily without replacing everything?
Thanks,
--Abel
Thanks,
--Abel
The signal from head unit to HK does not vary with volume so if you connect the sub from there, it will have the same VERY LOUD LEVEL at all volumes :(
So instead, you will have to pick up the signal from the speaker outputs of the HK amp. Problem now is that the HK amp "did its stuff" to the signals.
Which speaker outputs are best to use - one of the two dual voice coil rear speakers? If so, which one? Or maybe the signal to the lower door speakers?
Depending on HK mode, the system uses the speakers differently, so what is good in one mode might not work well in another mode - you will need to do lots of experimenting.
If you do, write down all the results and tell everyone else
PS:
One possibility that worries me is that there might not be any low bass frequencies coming out of the HK amp for you to send to the sub. The HK amp does lots of digital processing so it might filter out the signals which it knows the speakers cannot handle.
sorry... I have an Infinity Cappa Perfect 10 with an alpine v12 amp, that is making abot 320 w of power, and it was spliced off one of the rear speakers, if you do that then the volume will change with the stock unit, I would still recommend the bass **** though, as with mine, with the bass all the way down on the stock unit, it might still be a little loud for some people, but i like the way it sounds.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
Navigation & Audio Aftermarket radio with OEM navi question
quality_sound
09-12-2015 05:55 PM
