Navigation & Audio Radio display issues
Old 07-08-2014, 09:43 PM
IDLife Mini's Avatar
IDLife Mini
IDLife Mini is offline
I am looking at buying a 2007 R56 and the radio display is not fully illuminated. I have tried pressing buttons, turning ***** and nothing works to make any sounds.
I have searched all over this forum and read everything I can do to remove and replace the radio but is there any fix for a faded out or messed up display?
THANKS!!
Jeansblue (11-12-2018)
Old 07-09-2014, 02:37 PM
jared_g91's Avatar
jared_g91
jared_g91 is offline
My screen is starting to fade as well but I'm just replacing it with an aftermarket one, which is a lot cheaper and better IMO. It's a lot of work but well worth it.
dimitarserafimov (06-06-2023)
Old 07-09-2014, 03:19 PM
Big Jim Swade's Avatar
Big Jim Swade
Big Jim Swade is offline
You might watch Ebay for a used one.
Old 07-22-2014, 12:14 PM
mattjewell's Avatar
mattjewell
mattjewell is offline
Old 07-22-2014, 12:43 PM
EMKFLYER's Avatar
EMKFLYER
EMKFLYER is offline
I was going to buy a new/used stereo but I was afraid I would inherit someone else's issue. So, I found this on ebay. For $169, they replaced the LCD on my stereo unit, fixed all the sticky buttons and then mailed it back to me. It took about 2 weeks to fedex the stereo to California, repair it, then mail it back to me in Florida. I pulled my stereo out of the dash (took about 30 minutes) and then reinstalled it in about 30 minutes. I watched the following youtube video for instructions on how to remove the stereo.
http://www.ebay.com/itm/390811644151...84.m1423.l2649
The only challenge to the process is the stereo unit lost its memory and forgot my car has Bluetooth. I understand I need to hook up the GT1 programming software to the car to tell the stereo I have Bluetooth.
Overall, I'm extremely happy with the repair. The stereo looks and operates like new.
Ed
Old 07-29-2014, 08:26 PM
sporty1's Avatar
sporty1
sporty1 is offline
I am so happy I found this thread! I just bought a used 2009 Mini Clubman and my stereo is doing the same thing. It fades where some days it works and other days I can barely see it and chunks of the screen are unreadable. I'll give these guys in Long Beach a call, as they are real close to me, and hopefully they can help me fix the problem.
So glad you found them and are happy with their repair work! Can you post how you fix your bluetooth issue? I'm likely to have the same problem once the stereo is put back together. Much appreciated!!
Old 07-29-2014, 09:46 PM
EMKFLYER's Avatar
EMKFLYER
EMKFLYER is offline
I have not done the following programming yet because I have not found anyone in my area with the tool. However, below are the instructions for reprogramming the stereo unit.
"In some situations, once the device is disconnected, Bluetooth or other options will automatically reset causing the feature to be recoded back to the unit by BMW or an independent mechanic. It is a 10-15 minute service and requires a GT1 or Autologic programming tool. It loads the Bluetooth option back into the head unit."
Old 05-20-2017, 01:55 PM
shanksamillion's Avatar
shanksamillion
shanksamillion is offline
Does anyone have the procedures for replacing the LCD after the radio is out?
Old 05-21-2017, 12:35 AM
rkw's Avatar
rkw
rkw is offline
So, I happen to have a used speedo from eBay that I purchased long ago to experiment on for a project, and I looked at it.
The display wasn't designed to be replaceable, although it is possible if you have good technician skills to dissemble everything down to the circuit board level. Everything is assembled with screws and tabs and comes apart if you examine how the pieces fit together. However, the easier thing to do is replace the entire button/display module from a speedometer off eBay.
AZN Optics
Accessory Products
08-21-2015 02:03 PM
AZN Optics
08-21-2015 02:02 PM
AZN Optics
08-16-2015 11:52 PM
Herleman
08-16-2015 06:41 PM
MES11
Navigation and Audio
08-06-2015 08:52 AM
Quick Reply: Navigation & Audio Radio display issues
