Navigation & Audio Aux Jack issues
Old May 2, 2014 | 09:19 AM
djenks76's Avatar
djenks76
Aux Jack issues
I've had my 2007 r56 for about 6 months now and have never used the aux jack until yesterday. Connected my phone to it and selected it as the source on my radio. Music started playing...after a few minutes, I realized that I could only hear part of the music...basically I could the instruments but not the voices. Played around with the settings, swapped out the cable, even tried a different device. Any ideas before I start opening things up? I don't know if the jack is bad or maybe somethings loose.
Old May 2, 2014 | 10:05 AM
Grizld700's Avatar
Grizld700
Sounds like something needs to be pushed in further. Cable to phone? Cable to Aux? Aux to Head unit? If you have a phone case make sure it does interfere with the connection. I've had a case that looked good, but it kept the cable from making full connection, there had to be less than a millimeter of case material doing it, but once I removed the case and inserted the cable and voilà! It worked
Old May 2, 2014 | 10:42 AM
djenks76's Avatar
djenks76
I verified the cable (both cables that I tried) where pushed in all the way on both ends. My phone doesn't have a case and I also tried with ipod that didn't have a case...same results. My thoughts are that it's the jack itself or the cabling between it and the head unit.
Old May 2, 2014 | 11:07 AM
timfitz63's Avatar
timfitz63
I encountered a similar problem with my workplace computer and an old set of headphones. The jack on the headphones is similar to the one on the MINI AUX connector (1/8-in). My 'easy' solution in that case was to actually pull the plug out a bit until I got all of the sound. The ultimate solution became a new set of headphones...
But not seating the jack all the way into the receptacle is probably worth a try in your case. It definitely sounds like something somewhere is not making good contact, and I'd be suspicious of the Y-connector before anything else. If it's like mine, it tends to get stowed inside the glovebox, where it can get bent into all kinds of interesting shapes -- which does nothing for the soldered connections on the jacks...
Old May 2, 2014 | 03:43 PM
Mini2na's Avatar
Mini2na
I needed to have the jack (in the center cubby) replaced.
Old May 10, 2014 | 11:47 PM
!chili_red's Avatar
!chili_red
I had the same problem, the music sounded but there was no bass. I found the y-cable with the headphone type jack side had a short in it. If i wiggled the wire the sound would come in. I got a new cable and the new one is working.
Old May 11, 2014 | 04:14 PM
djenks76's Avatar
djenks76
Well, I pulled things apart, and tested the cables...ohm checked all the cables and no shorts. Ordering a new aux port...will post if that was it or not.
Old May 14, 2014 | 08:47 AM
JChristopherWalken's Avatar
JChristopherWalken
Sometimes I get this problem, and it's because the male end is pushed in slightly too far, just pulling it out 1-2 mm fixes it, but I have to jiggle it until sound comes out from all the speakers.
Old May 15, 2014 | 05:33 AM
djenks76's Avatar
djenks76
Just an update. The aux jack module was bad. This part did the trick.
http://www.ecstuning.com/Mini-2007-C...put/ES2675153/
W0TM8
Dec 19, 2019 07:50 AM
surfblue
Oct 24, 2018 01:20 AM
khumpert
Nov 30, 2015 11:48 AM
Inziladun
Sep 3, 2015 10:35 AM
