Navigation & Audio USB (Thumbdrive) Power
Old Apr 11, 2014 | 08:33 AM
Justaguy's Avatar
Justaguy
Quick question:
I have some road music loaded onto a small usb stick, no problems playing, accessing, or changing folders.
However, will the thumbdrive consume power, as indicated by the small led on the drive itself, without the key in the ignition - or am I required to remove after each use?
Thanks!
Old Apr 11, 2014 | 09:54 AM
AZdsrt's Avatar
AZdsrt
If it does consume power, can't be much. Mine has been plugged in for over a year. Mine doesn't have an LED; if you're worried about it, get another thumb drive without the LED..
Old Apr 11, 2014 | 06:33 PM
Btwyx's Avatar
Btwyx
The power turns off after about half an hour.
Old Apr 12, 2014 | 05:45 AM
Justaguy's Avatar
Justaguy
Thanks, appreciate your input. I finally had to replace the original battery in my Mini, and I am probably over-sensitive to preserving the new one. I know I could have sat in my car and "watched" it to see if / when it turned off, but thought I'd bring it to the board instead.
Cheers!
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Filmy
Sep 7, 2015 11:27 AM
mikeandtricie
Sep 4, 2015 01:42 PM
Ntety
Sep 2, 2015 08:39 PM
