Navigation & Audio Replacement Antenna Recommendations....
Originally Posted by 03Indigo
... but the Alta is a bit better fit overall for the base.
Originally Posted by memojo
If the am/fm antenna is not in the sharks fin on a mini w/ nav, where is it?
My reception stinks.
Thanks for the info on the shark fin and what's in it. With my antenna in the side windows, what can I do to improve reception?
memo
memo
Your bad reception has to do with the geography of the area (the distance from the radio source/relationship to mountains or valleys). Use CD or tapes as needed for areas where reception is poor.
Your radio can pick up only so much signal. Want better reception without changing the signal? Change the in dash head unit radio.
Consider satellite radio.
Consider getting an aftermarket audio upgrade shop to add a power antenna in your rear fender (don't think it would work in the bonnet except up near the cowl area and front door jam. Then hook up the antenna from the radio to the power antennae- you'll bypass the rear glass antenna.
When I installed the Kenwood head unit in the MINI, I noticed that the antenna's wire and its core is smaller than the standard universal antenna wiring. Many European cars (MINI, VW, etc.) use a different antenna wiring than the universal antenna wiring seen in most of the cars. Hence, I'll be replacing the the antenna and the wiring entirely with a high performance amplified antenna. After installing it next week, I can post the result if anyone is intereted. :smile:
In place of the OEM roof antenna will be a shark fin, painted white to match the white roof.
Metra 44UA200 high performance windshield or glass mount amplified antenna
- Separate AM & FM amplifiers for greatest performance.
- Separate ground wire for noise canceling & a red LED to confirm amplifier operation.
- Can mount on windshield behind mirror or on fixed side or back window.
- 14 1/2" / 37cm overall width. 93" / 236cm cable length.
The 2 lines embedded on the antenna could be the culprit for MINIs with OEM GPS.
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
Navigation & Audio FM Reception - Best Antenna?
bugeye1031
Aug 15, 2015 08:14 AM
Aug 7, 2015 05:55 AM
